CHEAP EF/D series stuff - Z6 pistons/rods - new headbolts - wheels - MPFI - CRX
TAKING OFFERS!
Click HERE for a full list and pictures. Please only go here if you are seriously interested, as I only have a limited amount of bandwidth that I can use from a certain server...
2 BF Goodrich G-Force TA drag radials - 225/45/17 - $80
-13" American Racing wheels - 4x100 - VERY lightweight - would be great for someone doing auto X or road racing with stock sized brakes. $100
-'93 Aerostar limited slip differential - comes with all of the hardware taken from the van. I have the serial number for the rear end so I may be able to get a ratio
-D series non-VTEC valve cover
-2 D series alternators
-D series AC compressor pending
-2 thermostat housings with "pump to thermostat" tube
-dismantled Garrett T3 .60 trim turbo. needs new compressor fan. Perfect for T3/T4 pending
-"black box" crankcase ventilation box
-D16Z6 pistons and rods - pulled from running motor with 98k on the clock. Rings are fine and not cracked, are still springy, but I would suggest replacing them.
-2 D series non-VTEC valve covers in black
-D series non-VTEC valve cover that is bare and slightly polished
-OBD0 Si (D16A6) injector resistor box
-2 D16A6 Si distributors - one has a bad coil and is missing the ignitor - other should all be there - both are missing at least one plug, which I have somewhere...
-New upper radiator hose for '96 Civic EX (D16Y8)
-D16Y8 head spout for upper radiator hose
-1 wire OBD0 O2 sensor
-2 upper timing belt covers -D series
-lower timing belt cover - D series
-Oldsmobile Alero fog lights and housings
-Interior mirror cover for passenger side - from '91 CRX Si
-Glove box latch for 90-91 CRX
-2 Tokico 'bump stops' - helps prevent the struts from bottoming out
-D16A6 starter - selanoid is bad, good for a core
-Honda tape deck - Pretty sure its for 90-93 Accord, has jack for the CD player, and also has the clip so the head unit will work without the CD player
-1 Z31 300ZX foglight
-EF Si steering rack - from an 89 CRX Si
-Various EF D series mounts
-Stock Ranger ECU - E0S
-60/40 seats with console for a regular cab Ranger. Tan in color, came from a '91 XLT
-Auto-Meter single gauge A pillar pod for 87-91 CRX SOLD
-Polished upper strut bar for EF/EG/maybe EK SOLD
'86TC turbo swap SOLD
-New Honda D16Z6 head bolts SOLD
Nissan 280ZX 14" wheels SOLD
I'm always willing to trade for something. I may want some S14 parts or Ranger parts down the line, but right now I'm looking to buy....
Integra GSR "fat five" wheels. Must be in good condition
Intake for EG coupe DX
Carbureted 302 motor
I'm located in NW Arkansas. Willing to ship anything reasonable as long as the buyer pays. I'm letting this stuff go for cheap guys.
Jason
Modified by I8ayellowcrayon at 9:09 PM 7/16/2005
Modified by I8ayellowcrayon at 8:38 PM 7/19/2005
Jason
YES. And I need to get rid of all of it!!
If it doesn't sell on here, its going to the recycling center. If you guys need something, LET ME KNOW, I'm selling this stuff CHEAP!
Mr.Spec
Jun 12, 2013 09:20 AM
CoreyR
Oct 26, 2006 08:03 PM
cottagecreep
14
Feb 13, 2003 09:33 AM
