comptech tie bar install
i previously used bsq kit and i had to take off the welded nuts at the back of the subframe. are the bolts that are used to mount the tie bar needed to be threaded to the welded nuts? how about the sway bar itself? i dont remember where the nuts once were.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 216.226.142.95:27016 »</TD></TR><TR><TD CLASS="quote">i previously used bsq kit and i had to take off the welded nuts at the back of the subframe. are the bolts that are used to mount the tie bar needed to be threaded to the welded nuts? how about the sway bar itself? i dont remember where the nuts once were.
thanks</TD></TR></TABLE>
Comptech tie bar comes with everything you need. I don't think you need the welded nut(s). Check out the installation instructions here:
http://www.comptechusa.com/instructions/ins065.pdf
figured it out. i looked over both diagrams and the bsq used the abs bracket hole as a mounting point while the comptech used the top mounting point and one on the tie bar.
problem solved, so comptech tie/sway bar can be used with no modifictions from a previous bsq kit install.
96gsrvtec1986
Apr 9, 2005 07:31 AM
