turbo gsr overheating
Old Jun 30, 2005 | 08:24 PM
ebp_dc2's Avatar
Default turbo gsr overheating
Just got my car a few days ago. Its running 10 lbs on a t3/t4. I have a temp gauge in the car and its reading really hot, like 220-240 and the car starts to bog pretty bad. I have the fan hotwired, but its still overheating. Radiator seems to be ok, but i cant be certain. Any idea what this could be? What is ideal running temperature??
Old Jul 1, 2005 | 12:09 PM
ebp_dc2's Avatar
Default Re: turbo gsr overheating (h22d dc2)
bump
Old Jul 1, 2005 | 12:43 PM
boostedcivicsir's Avatar
Mr. Badwrench
not to scare you, but when my old engine was eating itself up it overheated constantly. start with a t-stat. preferably a honda t-stat. you could remove the rad take it to a rad shop and have them flush it, or for 99 bucks get a new del sol dual core off of radiators.com
Old Jul 1, 2005 | 01:10 PM
ITSME4G63's Avatar
try flushing you rradiator, replace the thermostat, any leaks from under the water pump? It would be your waterpump if you see alot fo coolant coming from under your car. flushing the radiator and reoplacing the tsat are the cheapest and easiest ways to try and see if those were your problems. if you do so, do not yuse the orang/red radiator fluid, thats meant for gm cars, use the green ****.
Old Jul 1, 2005 | 02:19 PM
ebp_dc2's Avatar
Default Re: (ITSME4G63)
hmmmmm this sounds fishy, im gona go to a mechanic with it and get it checked out...what is ideal running temperature??
Christlike
Nov 8, 2023 09:32 AM
guille595
Jun 10, 2014 09:25 PM
szczerbanator
May 31, 2009 08:28 AM
krazyhmongboi
28
Feb 13, 2007 07:58 PM
PearlWhiteAccord
Sep 25, 2002 12:15 PM
