Rear Disc brake conversion (question)
Old Jun 30, 2005 | 08:19 PM
stickyfingers's Avatar
Default Rear Disc brake conversion (question)
when putting on disc brakes in the rear of an eg hatch,, does the brake line that comes off of the drum fit right up on the dics brake or o i have to modifiy it... by the way the rear disc brakes are off of a 99 si going on to an 92 dx hatch they will fit correct????
Old Jun 30, 2005 | 08:33 PM
Default Re: Rear Disc brake conversion (stickyfingers)
anybody
Old Jun 30, 2005 | 08:43 PM
six_speed's Avatar
you will need break lines from a disc set up. rear disc's conversion from 99-00 si will bolt up.
94+ integtra e break lines fit snggly on an eh civic hatch.
Old Jun 30, 2005 | 09:13 PM
Default Re: (six_speed)
so you cant use the drum brake line???
Old Jun 30, 2005 | 09:22 PM
screwballz's Avatar
Default Re: (stickyfingers)
nope. if i remember right i just used the soft brake lines from the front discs. you can get them pretty much anywhere but junk yard is probably the cheapest.
813EK
Jan 22, 2008 08:02 AM
enrique
Feb 26, 2004 05:17 PM
Egone
13
Aug 1, 2003 11:17 AM
fishnfst
Jun 11, 2003 09:11 AM
Jason kiDD
16
Apr 30, 2003 07:05 AM
