stroker kit cylinder head??
Old Jun 30, 2005 | 06:41 PM
Han Solo's Avatar
Default stroker kit cylinder head??
Does anyone know that if you get a stroker kit and bore out the cylinders too, do u have to get the part of the cylinder head bored out as well as the sleeves?? And if you do have too how??
Old Jun 30, 2005 | 07:49 PM
Han Solo's Avatar
Default Re: stroker kit cylinder head?? (jdmdelsolb16)
doesnt anyone know?????
Old Jun 30, 2005 | 09:00 PM
95dxhatch's Avatar
you dont have to touch the head when stroking a block. and the sleeves are the cylinder walls so if you're boring a block that means the sleeves/walls will be bored. you may want to do some research before you do anything
Old Jun 30, 2005 | 09:15 PM
jbs's Avatar
jbs
check out larry's page, theoldone.com. you'll find the info there. basically if the bore is stock, then no head work required if the bore is larger than stock, i believe the bowls on the head have to be reworked.
andrew714
Engine Machining & Assembly
Feb 17, 2016 07:10 PM
legendboy
Apr 12, 2005 04:27 PM
deascendent
Apr 3, 2004 08:39 AM
