Lowering spring / shock recommendations - eg with 16 inch rims & 50 series tire
Old Jun 30, 2005 | 07:57 AM
The Alchemist...
Guest
Posts: n/a
Default Lowering spring / shock recommendations - eg with 16 inch rims & 50 series tire
The car is mildly built but nothing crazy… Is their a spring / shock combo that will would good with those wheels?
Old Jun 30, 2005 | 09:04 PM
The Alchemist...
Guest
Posts: n/a
Default Re: Lowering spring / shock recommendations - eg with 16 inch rims & 50 series tire (w-a-o)
Old Jun 30, 2005 | 09:46 PM
94eg!'s Avatar
#1 Super Guy
Loved
I can't imagine running a 50 seriese tire on a 16" rim. You aren't going to be able to lower it at all without rubbing. I use 205/40/16 and I used to rub making turns with my old BFG Euro TAs (my newer Dunlop fm-901s don't rub). Of course I'm lowered 2.5"-3" though...
Thats going to be a tough one man...
Old Jun 30, 2005 | 09:50 PM
wheels01's Avatar
anything but tein
I blew up my tein HR coilovers, and installed a set of Koni yellows to use in the mean time, find they are better dampened than the teins were. Look at what the solo guys use. Most run a Koni with an ebiach. Seems to work well. The pro kit would do the trick. I suggest the yellow konis so you can adjust if you want to. Cheaper to buy that option now, then to have to buy it later. I know a few guys running the H&R cup kit, seems to work as well, but no adjustment, and for the price you could get Groundcontrol coilover sleeves and the konis, then you could find the setting you like best, rather than one someone else determined. Rember that each companies advertised drop, is approx and varies on cars options, milage, and use.
205-50-16 is a little big for an eg. I run 205 50 15 on the street. My allseasons/highway tires are 195/60/15 to make the car rev lower, but you need to be careful running something that big.
The Alchemist...
Guest
Posts: n/a
Default Re: Lowering spring / shock recommendations - eg with 16 inch rims & 50 series tire (94eg!)
Ok then how about a 45 series - would that work or do I need to go 40
Old Jun 30, 2005 | 09:54 PM
wheels01's Avatar
Anything can work, just a matter of how well. What are your plans? A bigger tire will make the speedo read slow, and slow your accerlation. A 45 is closer.
SupaMonkey
Feb 20, 2011 10:37 AM
'05 SubyD
11
Apr 11, 2005 06:50 AM
Peak A Boost
Dec 24, 2004 03:38 PM
Boostage
Sep 1, 2004 08:42 AM
turbotime
17
Jul 9, 2004 11:50 PM
