A/C leak. What should low pressure side read
I have a 91 Honda Accord, lx. I wanted A/c for my trip from NY to UT so I took it in to have it repaired. I changed the condenser before he filled it. He told me it was working and that I could pick it up. I tried the A/C and it didnt work. He put the machine on and said it should have 30 psi on the low side. It still wasnt cold. In missouri I decided to fill it. An aquantance told me the the low side pressure should be about the temperature of the day. I filled it to 55 psi and it really started getting cold. What is the pressure suppose to be on this model accord. I have searched everywhere and cannot find it. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 »</TD></TR><TR><TD CLASS="quote">Whatever it takes to be cold
no no no if you overfill the system you can blow seals, and most newer cars are pressure sensitive: if you overfill the system it will not work.
55 psi should be perfect.
</TD></TR></TABLE>no no no if you overfill the system you can blow seals, and most newer cars are pressure sensitive: if you overfill the system it will not work.
woooooooooooooo the temperature of the day????? no no no ..and 55 psi on low side is too high ..........should be around 20-35 ..depends on humidity and ambient temper they have an effect on it as well .your system capacity is 30-32 ozs
the expans valve is in the evaporator need to remove evap from car to replace exp valve
So The thermal expansion valve is in the evaporator. I know that fun to take out (ya Right). I think Ill change it and refill my system. I have had so many people tell me all different pressures. Thanks. Ill see what happens.
LeoGal99
Jul 1, 2019 06:05 PM
Lowski
Jul 22, 2007 08:14 AM
