92 Si, had to offset coilovers to make height even??!
Old Jun 30, 2005 | 03:56 AM
BDogggUT34's Avatar
Default 92 Si, had to offset coilovers to make height even??!
Like the title says, when i bought the car it had koni yellows and GC coilovers already installed but he height in the rear was higher on the passenger side. So i start to adjust the bottom perch to get the height even in the back, but i had to drop the perch almost all the way down to the bottom of the threads to even out the height. The drivers side rear perch is about halfway down. What could be wrong here?
Old Jun 30, 2005 | 06:54 AM
IHateJDM's Avatar
Default Re: 92 Si, had to offset coilovers to make height even??! (BDogggUT34)
driver's side always sits lower.
Old Jun 30, 2005 | 07:22 AM
Archidictus's Avatar
Unceasing Measure
Default Re: 92 Si, had to offset coilovers to make height even??! (IHateJDM)
Without corner weighting your car, each corner is going to weigh more or less than every other one, especially after factoring in the fact that your chunk of matter is sitting in the driver's seat.
Old Jun 30, 2005 | 07:39 AM
BDogggUT34's Avatar
Default Re: 92 Si, had to offset coilovers to make height even??! (Archidictus)
this height difference is also without me in the car. It was first noticeable by a three finger gap on the passenger side and then no gap on the driver side (rear). I dont know maybe its the way its supposed to be, it just seemed weird that i had to put the passenger perch all the way to the very bottom and the drivers side is set in the middle to get them to even out, also with absolutley nothing in the rear. thanks for the replies!
Old Jun 30, 2005 | 08:52 AM
chad's Avatar
Moderator
your car is BENT!!!!!!!
Old Jun 30, 2005 | 08:55 AM
sprayedcrx's Avatar
Default Re: 92 Si, had to offset coilovers to make height even??! (chad)
mine does the same thing except my passenger side is lower????
micah_m
Suspension & Brakes
15
Mar 29, 2011 10:54 AM
unknownally
Jun 20, 2010 08:31 AM
woody616
Aug 9, 2009 08:14 AM
BDogggUT34
Suspension & Brakes
Jan 4, 2005 03:13 PM
