Help identify this o2 sensor
So is it a reg. Honda 4-wire o2? The reason for asking is because I have two of the same honda 4 wire o2 and the wire colors are diff...Never had the time to check if the plugs were the same though, now that i think of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JapJunkie »</TD></TR><TR><TD CLASS="quote">So is it a reg. Honda 4-wire o2? The reason for asking is because I have two of the same honda 4 wire o2 and the wire colors are diff...Never had the time to check if the plugs were the same though, now that i think of it.</TD></TR></TABLE>
no its different from the reg four wire, its used only in the vx and hx modells.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by new moves »</TD></TR><TR><TD CLASS="quote">
no its different from the reg four wire, its used only in the vx and hx modells. </TD></TR></TABLE>
Yup. It's a five wire wideband, and pretty darn expensive (about 3 bills):
https://honda-tech.com/zerothread?id=1293418
What do you mean by 'modify' them?
You can use them in conjunction with a seperate WBO2 controller box that uses a L1H1 sensor - but that's about it.
Mfoehrkolb
Sep 15, 2011 06:45 PM
EARLdaSQUIRREL
Jan 13, 2003 07:09 PM
