LS Motor swap wont start.... HELP!!!
a friend of mine and myself swapped a B18b1 into a 89 Si hatch.. the wiring harness mounts right up, same as the D16 that was in it.. there was a few extra plugs, that we cant find spots for, but other than that, we tried to start it last night,and we got it to turn over, and sputter a lil bit.. now, it wont even turn over at all.... any suggestions ne one???? help plz
we are using the D16 one, b/c he had the same motor, in another Si, that got wrecked... and it worked in the old one,,, the grounds are all OK, and the stock ECU is still in the car
we took out the ECU, from the old Si, and put it in the new one, and the distributor is from the B18b1, we had that problem on the old car.. the car wont even turn over, it did once, then every time after that, it wont. the firing order is right, so i think it might be a starter issue. tried switching batteries, to see if one was bad, no help.. tried to turn it over with no compression, still didnt work. tomorrow we are going to try to push start the car, so we can try to zero in on the starter.. hopefully we will have more luck tomorrow. keep the advice comin tho... need all the help we can get...
oo. and for ne one else with this swap... is it just me, or is there no TPS sensor plug on the D16 harness??
DeviousCTR
14
May 4, 2006 03:28 AM
