Gas tank drain plug? Drag racers and circuit racers welcome...
Old Jun 29, 2005 | 07:46 PM
Haleiwa-Brando's Avatar
Default Gas tank drain plug? Drag racers and circuit racers welcome...
The engine that I've been slaving away on all winter is in it's very final stages and should be installed within the next couple weeks.
My question is: Have any of you ever welded a drain plug onto your gas tank so you can drain it's contents when needed? I'm simply looking to do something that will allow me to change out C16 to 93 Oct. (and visa-versa) when needed.
I have searched with no luck and excuse my ignorance if this is a feature that is currently built into all gas tanks. The car (gas tank) in question is a 1997 Acura Integra Type-R.
All feedback and better suggestions are welcome.
Old Jun 29, 2005 | 09:16 PM
Crasian's Avatar
in my 93 civic, it already has a drain plug....
Old Jun 29, 2005 | 09:21 PM
vaporboy12's Avatar
Default Re: (Crasian)
yeah civic's and integra have them. i know integra have them on the driver back side of the tank. 17mm wrench will take the nut loose
Old Jun 29, 2005 | 09:54 PM
turtle-eg's Avatar
Default Re: Gas tank drain plug? Drag racers and circuit racers welcome... (Haleiwa-Brando)
You can always just remove the hose from the fuel regulator and use the fuel pump to pump all the fuel into a container through that.
76 camaro car
Nov 15, 2018 04:33 PM
allnaturalb16
Jan 13, 2007 01:17 PM
Haleiwa-Brando
Jun 30, 2005 10:18 AM
Haleiwa-Brando
Jun 30, 2005 08:38 AM
1 Cam Wonder
30
Oct 21, 2004 10:14 PM
