99dc2 struts on 00si?
You can put DC2 (GSR) struts onto an Si, but you will need a spacer between the strut bracket and LCA. Spring rates will be different as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.GREEN »</TD></TR><TR><TD CLASS="quote">would it be better to sell what i have and buy a new setup? where can I get a spacer</TD></TR></TABLE>
You can make your own spacers but I wouldn't even recommend doing anything like that. If I were you I'd just buy the correct items.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.GREEN »</TD></TR><TR><TD CLASS="quote">what abought the spring I know there diffrent but what would happen if I put them on a si?
I know that I order Tokico Blues for my friend. The struts were for a 92-00 Civic. The only difference between the EG and EK is the front strut has the brake line mounted differently and the rear strut bracket is wide to accomodate both the EG/DC and EK LCAs. You might have a stiffer ride with the DC2 springs.
.1type.
Aug 7, 2007 01:42 PM
The Destroyer
Suspension & Brakes
16
Mar 23, 2005 11:55 AM
