H2B
Old Jun 29, 2005 | 06:28 PM
Eaglekper0046's Avatar
Default H2B install in rex
I need a full list of parts need to install a H2B in my rex. I already have a b16 with place racing mounts. I would also like to know what type of fab work I have to do. Any help would be great.
Modified by Eaglekper0046 at 7:48 PM 6/29/2005
Old Jun 29, 2005 | 06:37 PM
EL Vap133's Avatar
Default Re: H2B (Eaglekper0046)
H2B?
Old Jun 29, 2005 | 06:39 PM
Default Re: H2B (EL Vap133)
H22 with b-series trans
Old Jun 29, 2005 | 07:17 PM
Skinflute22's Avatar
don't waste your time with an h22 just do a b20 or b16
Old Jun 29, 2005 | 08:44 PM
Power Rev Racing's Avatar
Default Re: (Skinflute22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skinflute22 &raquo;</TD></TR><TR><TD CLASS="quote">don't waste your time with an h22 just do a b20 or b16</TD></TR></TABLE>
H22 makes more power than B16 and B20. So what do you mean dont waste your time?
Old Jun 29, 2005 | 09:08 PM
i mean its not worth the fab or the money when you could have a b16 and use the money you saved from the h22 and make a very very powerful b16 or b20... and the h22 requires custon axles and mounts and a tougher suspension..
Old Jun 29, 2005 | 10:30 PM
NikoZai's Avatar
https://honda-tech.com/zerothread?id=1290733
Here is my thread on the subject. There isn't an exact parts list yet. This kit is the closest thing you can get and it seems the company has a good rep from the few people that are buying from them. Great tech support. I'm going to end up going with them. So expensive tho, but not more than a built GSR
NO SAYING "Dont Go H22" just stfu. answer with something educational or don't post
Old Jun 29, 2005 | 10:36 PM
don't go with the h22
Old Jun 30, 2005 | 05:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skinflute22 &raquo;</TD></TR><TR><TD CLASS="quote">i mean its not worth the fab or the money when you could have a b16 and use the money you saved from the h22 and make a very very powerful b16 or b20... and the h22 requires custon axles and mounts and a tougher suspension..</TD></TR></TABLE>
When you use the B series tranny, its not as much Fab any more. You will be using the b series shift linkage, and motor mounts, so no cutting for cables or any of that. You only have to modify the block alittle for the half shaft. thats mostly all thats involved.
Old Jun 30, 2005 | 07:25 AM
Rywire's Avatar
Default Re: (Power Rev Racing)
But the h22 will sit way too low with the b series mounts... Unless its a drag car that is.
Old Jul 16, 2005 | 09:41 AM
Bserious's Avatar
Default Re: (droppedcrxsi)
No, not to low....to high.
The EF ground clearance is not effected when compared to a B-series. What is though is the hood clearance.
Old Jul 16, 2005 | 11:55 AM
NikoZai's Avatar
Default Re: (Bserious)
THATS AWSOME Thats exactly what i wanted to hear! I'm totally down to have to get a SIR Style CF hood, i'm not down to use skid plates LOL
Old Jul 16, 2005 | 11:57 AM
Bserious's Avatar
Default Re: (NikoZai)
You will need more than a SIR hood.
Putting an H/B settup in an EF is like running a deckplated B-series motor.
Old Jul 16, 2005 | 01:41 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserious &raquo;</TD></TR><TR><TD CLASS="quote">You will need more than a SIR hood.
Putting an H/B settup in an EF is like running a deckplated B-series motor.</TD></TR></TABLE>
i guess we could buy just the plate and make our own custom mounts?
Old Jul 16, 2005 | 04:29 PM
Bserious's Avatar
Default Re: (2point2)
The problem is relocating the engine/transmission to clear the hood will call for modified shift linkage, a custom axle combination, and introduce you to a terrible axle angle as present with the EG H22 bolt in kits.
So weight the options of the two...Hood vs. Mounts, Axles, Shift linkage, Axle Angle. A sacrifice will have to be made if the option is chosen.
Old Jul 18, 2005 | 05:14 PM
Bserious's Avatar
This is what I am talking about...
Relocating the engine backwards means you lose the mounting point above the intermediate axle.
(Sorry pics didn't come up first time)
Old Jul 20, 2005 | 09:55 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserious &raquo;</TD></TR><TR><TD CLASS="quote">No, not to low....to high.
The EF ground clearance is not effected when compared to a B-series. What is though is the hood clearance. </TD></TR></TABLE>
I see your reasoning, but I saw pictures of it done with the hasport b mounts, and the oilpan was sitting VERY low to the ground.
It was on the burgandy crx a few months back.
Old Jul 21, 2005 | 12:35 AM
UltimX's Avatar
also, another thing to think about is the rocker pads on the H series engines. They tend to wear down quickly. So addressing this is something that should be thought of carefully.
Old Jul 21, 2005 | 07:29 AM
Garrett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing &raquo;</TD></TR><TR><TD CLASS="quote">
H22 makes more power than B16 and B20. So what do you mean dont waste your time?</TD></TR></TABLE>
k20 make more power than h22 too
Old Jul 21, 2005 | 04:25 PM
Bserious's Avatar
There was a lot you did not see with that setup.
His concept did fit under the hood, but whatever way he did it, this rear portion of the block above the axle output would have had to be cut off. Not an option for our likings.
Plus I bet his ground clearance was dramatically affected.
Theres no way to space the center of the transmission and the axle outputs, so your sacrifice is hood clearance.
Modified by Bserious at 5:04 PM 7/22/2005
rleonekc
Aug 20, 2006 12:05 PM
89HTACH
Oct 27, 2004 09:40 AM
viney
Aug 19, 2003 12:39 PM
si91
Apr 14, 2002 06:08 PM
