My new car....and a question
hey im new...and heres my 6th gen accord. Now heres my question - I put the FF7's on earlier t/d, but after they were installed my check engine light comes up. Is it because my computer needs to be reset for the new wheels? any help appreciated.
Modified by Freeman at 7:24 PM 6/29/2005
The only way you could possibly effect the Engine Control Module (ECM) and set a light would be if Honda, in it's infinite wisdom, mounted (or incorporated) the VSS (Vehicle Speed Sensor) on one of the wheel hubs. Check to make sure you didn't disturb any wires during your project.
If this is not the case, it's probably coincidental
P
P
Ima have to look into it t/m. I talked to my local mechanic and he said the computer isnt used to the wheel spinning at non-factory settings
I also checked under the hood but everything seems in order, but thanks anyway
Your speedo and stuff may be off but I don't think it should affect the computer. I don't think that is your problem. Check the codes to see whats wrong with the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing »</TD></TR><TR><TD CLASS="quote">LMAO...your mechanic told you that your rims made your CEL come on? hahaha
Sorry...kinda funny, needed a laugh today.</TD></TR></TABLE>
READ BEFORE YOU SPEAK!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freeman »</TD></TR><TR><TD CLASS="quote">Ima have to look into it t/m. I talked to my local mechanic and he said the computer <FONT SIZE="3">isnt</FONT> used to the wheel spinning at non-factory settings I also checked under the hood but everything seems in order, but thanks anyway</TD></TR></TABLE>
You had to of fucked with some wires of some sort during your swap, new wheels WILL NOT set off the CEL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hometheaterman »</TD></TR><TR><TD CLASS="quote">Your speedo and stuff may be off but I don't think it should affect the computer.</TD></TR></TABLE>If your 4 tires didn't match EACH OTHER then your ABS computer would throw a code. But that's the ABS light, not the CEL. As long as they're all the same size, NONE of the computers have any way of knowing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hometheaterman »</TD></TR><TR><TD CLASS="quote">Check the codes to see whats wrong with the car. </TD></TR></TABLE>
Yes. There's like over 70 error codes, why would you want to guess when you can just have AutoZone read the code...
aside from that horrid downward pointing ebay muffler and that huge wheelwell gap, i would say that the car looks good.
your chk engine light is totally unrelated to the wheels themselves.
pull the code and let us know what you have come up with.
