correct way to wetsand and grit ?'s
Old Jun 29, 2005 | 04:37 PM
budget's Avatar
Default correct way to wetsand and grit ?'s
whats the correct way to wetsand?
-sand it a little then dip in water? dip it in water before hand?
-soapy water or regular water?
***is 1000 grit good enough for a semi bling look? or do i need 1500-2000
Old Jun 29, 2005 | 04:39 PM
DUFFM4N's Avatar
Default Re: correct way to wetsand and grit ?'s (Straight Flush)
i like to run the hose AS im sanding with 1000 grit
Old Jun 29, 2005 | 04:49 PM
budget's Avatar
Default Re: correct way to wetsand and grit ?'s (EF9eDDie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9eDDie &raquo;</TD></TR><TR><TD CLASS="quote">i like to run the hose AS im sanding with 1000 grit</TD></TR></TABLE>
Old Jun 29, 2005 | 06:28 PM
showbiz's Avatar
It depends on what type of surface and what your trying to achieve.
Old Jun 29, 2005 | 06:35 PM
CgiRLGO's Avatar
Old Jun 29, 2005 | 06:47 PM
3.504's Avatar
Default Re: correct way to wetsand and grit ?'s (CgiRLGO)
i like to use a sponge or a squirt bottle (when i'm polishing). i just wet the area i'm sanding, then i start sanding. i wipe off the area when i see the water get dirty.
if you mean bling w/ 1000 grit as in you're trying to polish... no it wont bling. you have to get some sort of polishing compound. same with paint, you have to get some sort of buffing compound.
for metal work, i like to stop at 400 or 600 grit wet sand and use a terry cloth with monthers mag and aluminum polish
Old Jun 29, 2005 | 07:31 PM
Cereal_Killer's Avatar
well i recently went through this process with a set of wheels i did the Lips on. what i did was wet the wheell/ area i was sanding 1st. and through out the process just continue to keep the area wet. the water i feel was almost like a lubricant inbetween the paper and the wheel lip. here is how mine came out
https://honda-tech.com/zerothread?id=1279884
quicksol95
Mar 18, 2006 10:02 AM
SPiFF
39
May 26, 2004 09:55 AM
ATS*Mark
May 19, 2004 08:44 PM
hatchback
Jun 26, 2003 07:08 PM
sackdz
Oct 16, 2002 04:02 AM
