can you pull codes with jumper off of obd2 gsr??
Old Jun 29, 2005 | 03:28 PM
blowme's Avatar
Default can you pull codes with jumper off of obd2 gsr??
I was doing a search trying to find ecu codes for gsr ecu, but im not sure if you can do that with a jumper wire or not. Obd2 motors have p codes so im not sure if i can jump the plug and count the flashes like i used to do with my obd1 motor
Old Jun 29, 2005 | 04:58 PM
98b18black's Avatar
Default Re: can you pull codes with jumper off of obd2 gsr?? (blowme)
Since it's OBDII why don't you just take it to Advance, Zone, or Oreilly's and have them run the codes for you with there OBDII scanner...it's free
hard_boiled_EG
May 3, 2008 09:56 PM
SCsol
Oct 7, 2005 05:35 AM
topher
Feb 2, 2002 10:46 AM
