94 Accord Ex Uninstalling Stock Radio
here http://www.dhost.info/accordin....html
or here http://www.installdr.com/Insta...7.pdf
Second one is a pdf file.
damn that **** seems WAY too complicated. id just take off the nut from the headunit by sticking my hand BEHIND the consule in which the head unit is mounted. i think its a waste of time to remove that whole center consule
It isn't that complicated to remove the console, just a few screws and it's better to do it the right way and not mess things up rather than doing it half *** and end up having to replace a broken part.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_EmO »</TD></TR><TR><TD CLASS="quote">damn that **** seems WAY too complicated. id just take off the nut from the head unit by sticking my hand BEHIND the consule in which the headunit is mounted. i think its a waste of time to remove that whole center consule</TD></TR></TABLE>
If that sounds too hard for you then you need to take your car to a professional and let them take care of the install then. The 1994-1997 Accord is one of the easiest installs to do if you are just a little knowledgeable at taking interior pieces apart. I have done many installs seeing that I am a professional installer and taking the center console out is the ONLY way to do it the right way and risk not damaging any parts. I'm bored tonight so here are a few pics of my install. Comments are welcome.
Damn I like that clean install, I know it has been done before but this is the first time I have seen an IPod in a car. Is there a bracket that is sold to mount it like that?
I used the monster cable case which came with a bracket and then I made a custom bracket out of aluminum stock to screw it into the side of my dash and then into the monster bracket. It was just a little L bracket that I had to make. It was actually alot easier than it looks and turned out really well I think.
There is the case. It just doesnt show the bracket. http://www.circuitcity.com/ssm...il.do
professorman
Apr 11, 2011 05:13 PM
zzzhondazzz
Dec 1, 2002 10:36 PM
