Need help ASAP!!!!
Old Jun 29, 2005 | 12:02 PM
gnar kill's Avatar
Default Need help ASAP!!!!
94 accord ex.....just swapped in a new motor stock for stock (sohc vtec 2.2) .....idle is jumping around and I need suggestions on what can be wrong....please guys don't tell me to search I need answers ASAP thanx
Casey
Old Jun 29, 2005 | 01:21 PM
Subwarrior's Avatar
Default Re: Need help ASAP!!!! (gnar kill)
I had same problem. What I did was removed fast idle thermo valve (on bottom of throttle body) and cleaned it with carb choke cleaner. The sporadic idle could also be brought on by an airbound cooling system. This is air bubbles in the coolant. Clean the FI thermo valve and flush radiator assuring u bleed all air out. There is an air purge valve on the top side of the thermostat. That did the trick for me.
Tgang94
Oct 19, 2012 08:00 AM
diyer
Aug 26, 2006 06:53 AM
aws140
Aug 26, 2005 07:51 PM
DK4200
Feb 23, 2003 09:33 AM
