How do you shorten the brake booster pushrod length?
Old Jun 29, 2005 | 11:21 AM
Jonathan_ED3's Avatar
Default How do you shorten the brake booster pushrod length?
I'm posting in here because I'm a former EG guy and I've always gotten a lot of help out of this forum. Anyway,
So I took my master cylinder back off and did a bunch of measuring.
Under vacuum, my brake booster pushrod extends an additional .150".
I measured the inside of my master cylinder, from flange to flange etc and did some math.
I need my booster pushrod to extend only ~1/4" from the inside booster flange under zero vacuum to have clearance on the master cylinder end.
I can get the pushrod to lengthen....but it won't retract any. It appears that I'm still 1/4" away from having the booster pushrod in far enough to not cause me master cylinder problems.
After a certain point, which still isn't far enough, the internal flange of the booster just starts backing itself into the booster.
It looks like this:
Am I screwed? Is there not a way to fix this? Does this mean that the brake booster rod is adjusted back as far as it can possibly go?
I need to be able to get this done using this brake booster. It's a 4+ hour job to remove it
For what it's worth, it's a '91 EX master cylinder with a '91 LX brake booster. I've had the setup before in a previous car and had no problems whatsoever.
I really need some help/ideas here! I've been having problems with my brakes sticking/dragging and I think I've finally narrowed it down to this.
ilvi3tkidxx
Oct 16, 2008 06:51 PM
Jonathan_ED3
Jun 29, 2005 07:47 PM
gt30typer
Jan 31, 2005 06:18 PM
