have you guys ever heard of this motor( motor swap q)
on the block its stamped d16a. on the valve cover it says vtec. and it has the vtec solenoid. and spark plugs are up front(like all d series vtec motors) does anyone have the stats on this motor. i put it in my 92 civic. but now i got a crx si all stock but the d16a6 in it has 300,000 miles. so i was thinking of pullin the d16a vtec and putting it in the crx. now is it worth pulling it or shuold i just get a d16z6? also can somone who did this swap tell me some quarter mile times and is it really worth all the work? and does anyone konw where i can a z6 for cheap. im in ny and the junyard around here dont let you pull your own ****
i think you might be right. casue i someon else toled me it was a single cam vtec zc its obd1 casue it was plug and play in a 92 civic. is that better thean a z6? any hp an tq stats please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">on the block its stamped d16a. on the valve cover it says vtec. and it has the vtec solenoid. and spark plugs are up front(like all d series vtec motors) does anyone have the stats on this motor. i put it in my 92 civic. but now i got a crx si all stock but the d16a6 in it has 300,000 miles. so i was thinking of pullin the d16a vtec and putting it in the crx. </TD></TR></TABLE>
Ok I bought this motor here in CA for $300 complete motor, no tranny or ecu. here's a pic:
it's stamped "d16a" only.
I'm puting it into my CRX this weekend, it's supposedly was used in 2 cars that I've been told so far honda had out there. It was in a european ferio and a mexican civic. it's very similar to the 92-95 Si or Ex, if not exactly the same.
going in this weekend
good luck!!
good luck!!
I had the same question when I was doin my motor swap a couple months back. My research came back that the D16A is JDM VTEC-E...I mated that block with a Z6 head. I can't find the info I had on it before (it was over 7 months ago). I like the set-up...
Nice lookin car by the way...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">yup thats the one!!!!! but mine has a silver cover. any tq numbers on that?</TD></TR></TABLE>
Japanese engine, almost identical to d16z6 with a little bigger cam and like .2 more compression. just like a sohc vtec zc engine
i had that engin in my 5g civic sedan. automatic. and when vtec kicks it you defintely feel the **** move. but i wanted to konw if i threw it in my crx (stick) would it make that much of a diffference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource »</TD></TR><TR><TD CLASS="quote">Look up HONDA DOMANI D16A
130ps
It's RIGHT THERE on the Japanese website
You are WRONG
140 HP :]
I believe it came in the 92-95 VT-i models.
130ps
You are WRONG
140 HP :]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX »</TD></TR><TR><TD CLASS="quote">
You are WRONG
140 HP :]
I believe it came in the 92-95 VT-i models.</TD></TR></TABLE>\
ps and horsepower are different ratings so you are both right. I should give you a thumb down for not knowing the difference.
You are WRONG
140 HP :]
FYI...it's a bitch finding parts for this set-up. Waterpump, timing belt, etc. It's worth it now though
Also, you can up the compression with a Y8 head gasket...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doitdub »</TD></TR><TR><TD CLASS="quote">FYI...it's a bitch finding parts for this set-up. Waterpump, timing belt, etc. It's worth it now though
Also, you can up the compression with a Y8 head gasket...</TD></TR></TABLE>
Really. My friend has a boosted D16A with 10 lbs on a t3/t4 and he said that all Singlecam Vtec parts from the Z6/Y8 are interchangeable.
You are WRONG
140 HP :]
http://www.honda.co.jp/factboo....html
Make sure you swallow
yeah i just use z6 **** on it. water pump ect. i also read in temple of vtec that there are two of them. one is 105 hp and the other is 130 for the awd something or other.
Well I know we had a hard time finding a waterpump to fit...and I have tried a couple different timing belts with none of them fitting perfect...z6 on there now - fits the best but still loose.
95civicSirCoupe
20
Jul 1, 2004 07:49 AM
89 CRX SI
15
Mar 28, 2002 09:04 AM
