DX rear sway bar help, DA lower arms.
Old Jun 29, 2005 | 11:07 AM
vegaskurt's Avatar
Default DX rear sway bar help, DA lower arms.
I have the rear disc swap parts from a 91 DA including the lower arms and sway bar. The control arm bushings are jacked on the DA parts so I need to hold off on doing the complete swap till I can afford the honda or pro-thane bushings.
My question is, I want to put the sway bar on this weekend. Can I just swap the lower arms out or am I going to run into an alignment issue?
Old Jun 29, 2005 | 12:23 PM
eda6's Avatar
Default Re: DX rear sway bar help, DA lower arms. (vegaskurt)
The DA lca will bolt up although they're slightly longer than your existing lcas.
You won't have alignment issues unless you use DA compensator arms.
Old Jun 29, 2005 | 04:58 PM
bagpipe goatee's Avatar
they say they're slightly longer, but i put bolts through both the holes, and they weren't. the outsides were longer, but that is just the casting on the mold. the actual bushings are the same distance on the da arms.
other thing, you have to be able to bolt it to the underside of the car...
Old Jun 30, 2005 | 08:23 AM
vegaskurt's Avatar
Default Re: (bagpipe goatee)
Bolt to bolt they are abount 1 or 2mm longer. But that could just be the bushings that I had. I took a side by side pic of them. The only thing majorly different (besides the sway bar mount) is that the shock mount angle is different. So I think the rear of my car may be slightly taller now... not sure.
I'm going to put the sway bar on this weekend, my dx actually has the threaded bolt holes for it on the body.
civic DX on the left, integra on the right.
Old Jun 30, 2005 | 09:25 AM
i forgot about that.
the schock mount difference, that decreases the leverarm that she strut has on the control arm, thus effectively reducing your spring rates by a little bit. i have da arms in my car, i don't notice much difference. i would like stiffer springs back there, though.
Old Jun 30, 2005 | 09:55 AM
vegaskurt's Avatar
It doesnt seem like it affected the ride height at all. So far so good. I'll mount the sway bar later this weekend. Need to replace an axle now.... noticed it last night.
HustonB
13
Jan 3, 2013 11:36 AM
anngsr1
Apr 21, 2007 12:00 PM
shanghaining
Jun 2, 2006 10:21 PM
DerangedEG
May 14, 2004 11:48 AM
accordfreak
Mar 31, 2004 08:27 PM
