Suspension & Brakes Theory, alignment, spring rates....
when is wide too wide?
Old Jun 29, 2005 | 08:32 AM
crxgator's Avatar
Default when is wide too wide?
I have a couple of people on a local forum trying to tell me that a 18 x10 inch rim will help out the handling and launching of a mr2...i completely think different because the rim seems to be way to big to help more than hinder...am i thinking logically, or is it correct to still use the "wider is better" term in this situation?
Old Jun 29, 2005 | 09:18 AM
goforbroke's Avatar
MEAT PATTY
Default Re: when is wide too wide? (crxgator)
18" on a toyota MR2? I highly doubt that huge rim is going to help on launching. You probably won't even be able to generate enough heat in the tire to even help on launching. Wider is not always better like I mentioned you have to be able to get enough heat in the tire for it be benefical. Even with handling the Mr2 probably isn't even heavy enough to get enough heat in the tires.
Old Jun 29, 2005 | 09:29 AM
vtecvoodoo's Avatar
Future Texas Boy
too much rotational mass.
Old Jul 6, 2005 | 02:53 PM
MidShipCivic's Avatar
JGTC race cars use such a size. 330/30/18
It's not the rim that gonna help them launch its the tire choices they get to use.
Old Jul 6, 2005 | 10:44 PM
IntegraTypeRice's Avatar
Default Re: when is wide too wide? (vtecvoodoo)
I dont see any reason to go with that large of a rim. I had 17s on my MR2, I wished I had some 16s.
Old Jul 6, 2005 | 10:48 PM
eMpAtHy's Avatar
Default Re: (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">JGTC race cars use such a size. 330/30/18
It's not the rim that gonna help them launch its the tire choices they get to use.</TD></TR></TABLE>
they also have like 5045092590329053290 gazillion hp.
18x10 is friggin huge..17x9 is more than enough imo...
Old Jul 6, 2005 | 11:22 PM
Default Re: (eMpAtHy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy &raquo;</TD></TR><TR><TD CLASS="quote">they also have like 5045092590329053290 gazillion hp.
18x10 is friggin huge..17x9 is more than enough imo...</TD></TR></TABLE>
They have 500HP.
Old Jul 7, 2005 | 10:02 AM
DarkDragon's Avatar
it is possible for a too wide tire. If one is to wide the cars weight will be distributed over a wider area thus reducing traction. Have you seen tires used on snow and ice rally cars? They are literly smaller than a 185 width tire but with spikes. A cre member explained the reasoning about the small width and he said cuz more of the cars weight is pressing on the smaller surface area pushing the tire down further, think about a snow shoe concept wider you dont sink, skinnyer you will
Old Jul 7, 2005 | 11:09 AM
msmotorsports's Avatar
Having that large of a rim would be a terrible choice for launching a car. Fist of all the rotational mass is very high. Second, the tire you will be putting on the 18 will not have much sidewall. May be better for cornering but very bad for launching a car as the tire cannot bite as hard as a tire with a larger sidewall.
Old Jul 7, 2005 | 11:29 PM
Default Re: when is wide too wide? (msmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">Having that large of a rim would be a terrible choice for launching a car. Fist of all the rotational mass is very high. Second, the tire you will be putting on the 18 will not have much sidewall. May be better for cornering but very bad for launching a car as the tire cannot bite as hard as a tire with a larger sidewall. </TD></TR></TABLE>
Depends (Fender flares) those 330/30/18 have 5 inches of side wall.
Rotational inertia.... oh well sacrifices are made for grip.
That snow rally stuff doesn't apply because there using spikes .
Old Jul 8, 2005 | 07:28 PM
mamaboy's Avatar
general rule. fit the smallest wheel that will fit over the brakes. sidewalls will help with your overall grip and launching. if you look under those jgtc cars they have huge rotors and calipers. they need big brakes to clear them, but at the same time they don't have 35 series tires. they have highly modified fenders and large sidewalls.
Rooftop voter
May 21, 2009 05:10 AM
young noob #2
Jan 3, 2009 05:00 PM
Coldness
May 30, 2006 02:09 PM
ChiBoy
Oct 15, 2003 08:53 PM
