Aftermarket Radio Question
Old Jun 29, 2005 | 04:56 AM
93egsi's Avatar
Default Aftermarket Radio Question
Fellow members......Well I got tired of my stock radio, so I bought a Kenwood and installed it myself, but during the install I think I may have broken the antenna plug that plugs back into the head unit. That little damn metal piece thats in there is so damn delicate. I couldn't find a solution so I just plugged it in, my reception is very bad now. Is there a way I could fix that? because I pulled the wire a little and it seems like that wire runs forever......didn't know where it connected to.....some help would be greatly appreciated. Thanks alot
Old Jun 29, 2005 | 05:13 AM
rewhipple's Avatar
Default Re: Aftermarket Radio Question (93egsi)
not sure if it can be repaired, but i do know that the ant runs from the back of the radio all the way to the ant on the outside of the car. my guess though is that the connector could be fixed if you had the conector and the correct tool to crimp it. let me know how you make out
Old Jun 29, 2005 | 06:15 AM
93egsi's Avatar
Default Re: Aftermarket Radio Question (rewhipple)
TTT.....anyone else?
Old Jun 29, 2005 | 07:18 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewhipple &raquo;</TD></TR><TR><TD CLASS="quote"> my guess though is that the connector could be fixed if you had the conector and the correct tool to crimp it. let me know how you make out </TD></TR></TABLE>
agree, or get sirius
Old Jun 29, 2005 | 08:01 AM
kaboomwoom's Avatar
no idea
Old Jun 29, 2005 | 08:39 AM
rewhipple's Avatar
Default Re: (kaboomwoom)
best guess would to search and see if some one make a repair kit or go to your local electronics str.
Old Jun 29, 2005 | 09:51 AM
Relic1's Avatar
The antenna wire runs all the way to the antenna on the outside of the car. which runs up the drivers side of the windsheild.
if you pulled off the inner wire from the radio plug then it can be re-crimped or repaired by a really good car audio shop.
If you pulled it loose from the antenna side you have to replace the entire antenna and cable.
~$20 part, an hour or so to put in. about a 6/10 on a PITA factor.
Old Jun 29, 2005 | 10:06 AM
93egsi's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">The antenna wire runs all the way to the antenna on the outside of the car. which runs up the drivers side of the windsheild.
~$20 part, an hour or so to put in. about a 6/10 on a PITA factor.</TD></TR></TABLE>
Awesome.....thanks for the info....well off to find a car audio shop
do you think Best Buy or Circuit City could do it?
Old Jun 29, 2005 | 10:13 AM
Deemeetree's Avatar
Electrician
Get a used one from the junker. I paid $10 for mine.
97teg415
Audio / Security / Video
Sep 20, 2007 07:30 AM
bpr0422
20
Jul 21, 2006 03:10 AM
TurboEM1
Dec 7, 2005 09:27 AM
CrazyModGSR
May 14, 2004 10:21 PM
MLogan
Aug 11, 2003 03:02 PM
