HELP....stupid newbie question
ok ok...i'm new to the darkside...what kind of oil do i use in a turbo GSR...i've always been a allmotor guy runnin my 5w-40 synthetic....what is the best to use for the turbo...please help i wanna start my motor all i have left to do is hook up the charge pipes........thx
you'll be fine with regular engine oil used on a honda. make sure u pour a little oil in the turbo bearing or prime the oil system prior to startup.
One little thing, if it is a brand new motor you should stear clear of synthetic right off the bat. Brake it in with regular, drain it, flush it with a quart of syn. and then syn all the way home. Regular oil leaves more residue that will stick and adhear to parts that will help in the brake in.
