Air to fuel gauge
Old Jun 29, 2005 | 12:32 AM
teler86's Avatar
Default Air to fuel gauge
I am running a b16 obd-0, and thus i have 2 o2 sensors. I want to hook up an air to fuel gauge and was wondering if it makes a difference from what o2 sensor i splice from.
Old Jun 29, 2005 | 01:31 AM
limpy's Avatar
Default Re: Air to fuel gauge (teler86)
pretty sure that the gauge will not work correctly without a wideband o2 in which case splice from the wideband. if it does work correctly then i would go from the primary o2 (the one that you didn't have to run the wire to)
Old Jun 29, 2005 | 05:24 AM
teler86's Avatar
Default Re: Air to fuel gauge (limpy)
why wouldnt it run with out a wideband o2?
Old Jun 29, 2005 | 06:36 AM
EP3_05's Avatar
It will work fine without the wideband but will not be very accurate. Hook the A/F gauge to the primary O2 sensor and it should be fine. If you want an accurate reading of the A/F ratio get a wideband setup.
Old Jun 29, 2005 | 07:47 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
if your just talking about a regular autometer narrowband afr gauge, then just hook it to the first o2 sensor and it will work fine. its really not worth the money or hassle though.
a wideband o2 setup will come with its own meter/gauge and will cost about 6-8 times as much as the narrowband gauge.
Old Jun 30, 2005 | 03:55 AM
teler86's Avatar
Default Re: Air to fuel gauge (fastcrxsi90)
Thanks for your help guys
peddyeye
Dec 1, 2008 01:52 AM
nytosc
Aug 23, 2008 07:40 AM
kcjohnnyboy
Sep 29, 2004 10:20 AM
Greyout
Apr 21, 2002 08:55 AM
