Fuel pump issues
Old Jun 28, 2005 | 07:29 PM
Whig-it's Avatar
Default Fuel pump issues
First, i did search, and have not figured out the problem. SO i installed an Walbro 255 LPH High Pressure Fuel Pump and now whan i turn the car on i don't get the fuel pump priming, or turning on. The car is a 92 civic DX HB with B18b. SO i followed the troubleshouting stuff in my service manual, and got semi confused. First i tested the pump by un hooking the main realy, and connecting pin 6 and 7, and the pump turns on. THe i tested the realy, thay was good, then i did a few more tests, all good. I thought the issus was the main wiring harness was hacke dfrom the owner before me, so i got a new one from another civic, that didn't do anything. Laso tried 2 different ecu, no luck. I am confused and need help. Thanks
Old Jun 29, 2005 | 06:22 AM
Whig-it's Avatar
bump
Old Jun 29, 2005 | 06:33 AM
Mohsin's Avatar
check your main relay for any dry joints.. it could be an intermittent problem?
Mohsin
Old Jun 29, 2005 | 07:41 AM
Chiovnidca's Avatar
Default Re: (Mohsin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin &raquo;</TD></TR><TR><TD CLASS="quote"> it could be an intermittent problem?
Main relay problems usually are. Check it for cracked solder joints. Have you checked your fuses?
Old Jun 29, 2005 | 07:49 AM
Whig-it's Avatar
well, i figured it out, it was a combo of a hacked harness and a bad ground, so it works now, so happy
logjammin
17
Jul 29, 2013 07:59 AM
Jay_Mills
Mar 16, 2012 10:05 AM
B16afmaxt
Mar 22, 2010 06:26 AM
mikester1222
May 20, 2008 08:08 PM
kaychi
Mar 28, 2007 03:56 PM
