...Questions, Need Help, Tire and Rim Sizing Opinions?
Old Jun 28, 2005 | 07:27 PM
QualityMaterial's Avatar
Default ...Questions, Need Help, Tire and Rim Sizing Opinions?
...Whatsup guys...Im planning on ordering some new wheels for my eg hatch...regardless of the which rim i order...i was planning on ordering 15's...but a guy i spoke to the other day said 16s would also be alright, while im sure they would work, which ones in general seem to work better with/look better on eg hatches...16s might be nice, but might they be too big? and also, whats the bolt patter? obviously its 4 lug, but is 4x100?4x114.3?etc...and as for tires, my old rota slips were 195/55/15 falkens all around and seemed good, the si's im sittin on now, 2 are 195/55/15 which are good, but the other 2 are 205/55/15 and were too big for the front, as they would scrape the wheel well when cuttting all the way left or right, so i had to switch them to the back...i do not want on the new tires i will be ordering...so my question is whats the best rim/tire size setup for me? i definitely need help with this and need advice so i dont order the wrong sizes...thanks guys...
Old Jun 28, 2005 | 07:30 PM
Jon V's Avatar
Default Re: ...Questions, Need Help, Tire and Rim Sizing Opinions? (QualityMaterial)
what kind of springs do you have? 195/55/15 sounds like you size...
BlueIntegraBoy's Avatar
15's are nice. Your bolt pattern is 4x100. I am running Buddy Club SFs 15x6.5 +42 offset 205/50/15 Azenis. I only rub on hard turns or little bit harder than normal turns with a passenger. A lot of people run 195/50/15. But, rubbing is also a factor with offset and wheel width. I say stick with 195/50/15 for your Si's.
Old Jun 28, 2005 | 07:40 PM
Default Re: ...Questions, Need Help, Tire and Rim Sizing Opinions? (Jon V)
im runnin on skunk2 lowering springs and an otherwise stock suspension...so 4x100...w/ 15s and 195/55/15?...ive seen for 16s that there are 205/45/16 and 205/50/16...the 45 and 50 difference, what is that in relation to? and if i choose to get 16s w/ say the 205/45/16 will those work so that there will be no rubbing? or will those be too big regardless?
Old Jun 28, 2005 | 07:44 PM
Deftones's Avatar
My friends hatch is dropped 2.5 inches and he has 16 inch Rota Circuit 8's with 205/45/16's and still has clearance; he can even drop another half inch to maybe even a full inch.
Old Jun 28, 2005 | 07:46 PM
Your tire width of 205mm is rubbing your fender. The 45 or 50 is your series. For example 205/45/16, 45% of 205mm is your tire height from edge of rim to the outer edge of the tire. So 205/45/16 has a smaller diameter than 205/50/16. You might get rubbing on 205/45/16, depends on the offset of your rim as well.
Old Jun 28, 2005 | 07:51 PM
Default Re: ...Questions, Need Help, Tire and Rim Sizing Opinions? (BlueIntegraBoy)
...thanks its starting to clear up for me now...2 of the si's im currently sittin on, the 2 that were rubbing , are wrapped in bfg's 205/55/15...so is it possible that if i get 205/ 45 /16 with the new 16s, that the smaller 45 will help prevent the rubbing? even with the bigger size 205s?
Old Jun 28, 2005 | 08:03 PM
Deftones's Avatar
see if this helps you understand tire sizing better
http://www.discounttiredirect....e.jsp
Old Jun 28, 2005 | 08:06 PM
dohcdelsol's Avatar
I have 99-00 si wheels with 195/55/15 tires. My eg hatch is lowered on h&r race springs. I rub when im turning sharply at slow speeds, ie parking into a parking spot.
Personally... i would recommend 195/50/15 for a 15 inch rim from experience. Then you can go that 2.5 inch drop without worry for your eg hatch. But you dont really need that much of a drop. 2.25 is more then enough.
Stateing all this from experience
mikebaker422
Jul 10, 2013 11:45 PM
slick702
May 25, 2011 03:16 PM
pumpkinz6
Mar 23, 2009 07:15 PM
Mark
Dec 7, 2007 07:27 AM
DelSolDon
Mar 15, 2005 02:33 PM
