every time i press the brake the door ajar light flases an beeps.
Old Jun 28, 2005 | 05:49 PM
jacobforcecrx's Avatar
Default every time i press the brake the door ajar light flases an beeps.
every time i press the brake the door ajar light comes on and it is annoying the hell out of me. I checked the fuses they seem okay. And i also need a fender for a 90 crx. HELP
Old Jun 28, 2005 | 05:51 PM
dr_latino999's Avatar
Default Re: every time i press the brake the door ajar light flases an beeps. (jacobforcecrx)
Check for a short in the wire where your brake light switch circuit is coming in contact with the door switch.
Old Jul 2, 2005 | 05:47 PM
jdeemseerx's Avatar
does your horn work?
Old Jul 3, 2005 | 06:06 AM
Autoworks's Avatar
I bet thats irritating. I'd check for a wire grounded out.
Old Jul 7, 2005 | 07:47 AM
Default Re: every time i press the brake the door ajar light flases an beeps. (Autoworks)
Fixed it! It ended up being the fuse under the hood. I didn't even check those. Thanks for all yhe help i'm still looking for a fender though. Also i now need a new exhaust i backed into a curb and bent mine all to ****.
Magick211's Avatar
Check the classifieds for a fender/ or ebay
Old Jul 7, 2005 | 07:36 PM
Default Re: every time i press the brake the door ajar light flases an beeps. (Magick211)
lett me know i also need the exhaust. Just let me know something. and the drivers side window track.
Old Jul 7, 2005 | 07:54 PM
i really need a fender though.
Old Mar 31, 2011 | 07:38 PM
31flavorscivic's Avatar
sorry to thread-necromance here but you just helped us solve a two month long problem in about 20 seconds. Lord knows what made the fuse blow but it hasn't happened again.
Brake-Horn fuse 20a under the hood was blown. Popped a new one in and we are good to go.
thank you thank you thank you thank you!!!!!!!
Old Mar 31, 2011 | 10:07 PM
90efzc's Avatar
Weird, would your door ajar light come on too?
Does anyone know why that happened to the op? I know the solution was a fuse but if the fuse was for the brake/horn why would it affect the door ajar light?
Old May 24, 2017 | 09:31 AM
91CTR's Avatar
Thread necromancing again.
I've had this issue for the last couple weeks. googled it and found someone with my same car who fixed this issue 12 years ago.
problem solved in under a minute.
Just another reason why I love this forum!
Old May 24, 2017 | 11:21 AM
Tyson's Avatar
I'm ok with necromancing threads by confirming helpful content like the last two did.
As for why? Probably designed purposely so the driver knows there's an issue so that it's fixed sooner than the risk of driving without brake lights. Just a thought.
lickety
Honda Civic (2001 - 2005)
Aug 25, 2013 12:50 PM
IntegraGuy16
Jul 30, 2010 10:33 AM
CRX T-Si
16
Jun 23, 2006 11:30 PM
Wilky
16
Jan 24, 2006 04:21 PM
GT_Alpha
May 8, 2005 08:21 PM
