help with removing bolts!
i'm working on removing my old cat-back and am having trouble removing the three bolts holding the b-pipe onto the cat, they are all rusted and whatnot, what all methods have you guys used, or can you think of that i can try to remove them. i do not have an air compressor so anything involving one is out. thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRCivic97 »</TD></TR><TR><TD CLASS="quote">PB Blaster,
WD-40,
Air Hammer,
Gas Torch,
Try in that order.
that's about right.you can also substitute a cutoff wheel for the Air Hammer/Torch part.
Chris
WD-40,
Air Hammer,
Gas Torch,
Try in that order.
</TD></TR></TABLE>that's about right.you can also substitute a cutoff wheel for the Air Hammer/Torch part.
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree »</TD></TR><TR><TD CLASS="quote">I just use a normal 1/2" ratchet. It's called elbow grease. Damn panzys.
</TD></TR></TABLE>apparently you've never had one of these where the three cat bolts are so rusted that the heads are round.elbow grease and a 1/2" ratchet won't fix that.
Chris
</TD></TR></TABLE>apparently you've never had one of these where the three cat bolts are so rusted that the heads are round.elbow grease and a 1/2" ratchet won't fix that.Chris
they have been drenched in pb all day now, looks like my buddy jesse is going to help me out tomorrow, i think he has an air chisel and didn't even think of him lol! thanks for the advice fellas!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">apparently you've never had one of these where the three cat bolts are so rusted that the heads are round.elbow grease and a 1/2" ratchet won't fix that.
Chris</TD></TR></TABLE>
Actually, I have. Broke my stock header bolts loose with WD40 and a 1/2" ratchet to place a new gasket in between. But, my bolts didn't round off.
Tad
18
Apr 16, 2006 05:01 PM
civiccoupe94
34
Nov 17, 2005 08:15 AM
Traction
Jul 30, 2004 07:01 PM
