te37 volk racing wheel
Old Jun 28, 2005 | 04:25 PM
hondastreet's Avatar
Default te37 volk racing wheel
I want to know if is possible to install on type R this following wheel:
Patern: 5X114.3 do not exist, sorry
OFF SET: 0
Modified by hondastreet at 2:27 AM 6/29/2005
Old Jun 28, 2005 | 04:29 PM
Integra21's Avatar
Default Re: te37 volk racing wheel (hondastreet)
i dont know about the offset
Old Jun 28, 2005 | 04:30 PM
ZygSpeed's Avatar
Check your offset, if its really "0 (zero)" then I doubt it will fit a normal car.
Old Jun 28, 2005 | 04:33 PM
Default Re: te37 volk racing wheel (zygspeed)
yes i'm sure about the offset..
Old Jun 28, 2005 | 04:38 PM
i know also that this one fit on GSR
PATERN: 4X100
off set: 28
Old Jun 28, 2005 | 04:46 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondastreet &raquo;</TD></TR><TR><TD CLASS="quote">yes i'm sure about the offset..</TD></TR></TABLE>
Well, first of all unless it's a JDM pre 96 or whatever with their 4x114.3 bolt pattern, No it won't work.
Now if you can get past the lug pattern and missing one lug. As I understand it, it could work. But you wouldn't want it. The wheel/tire will stick out so much further than the fenders.
Old Jun 28, 2005 | 04:47 PM
Splat's Avatar
Collector-o-Guns and Drinker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondastreet &raquo;</TD></TR><TR><TD CLASS="quote">i know also that this one fit on GSR
PATERN: 4X114.3
off set: 28 </TD></TR></TABLE>
I thought GSR was 4x100?
Old Jun 28, 2005 | 04:49 PM
1GreyTeg's Avatar
PATERN: 4X114.3
Here, read this to get a better understanding of how offsets on wheels work:
http://www.fordownersclub.com/....html
For the Te37 on an R you want as close to stock as you can get which fits over the calipers. For me it's a 15x7" +43.
Stock R offset is +50.
Old Jun 28, 2005 | 05:08 PM
Default Re: te37 volk racing wheel (1GreyTeg)
ok, je n'ai pas réfléchie, sorry
I will buy 15x8, 5-114.3, 27 offset
Old Jun 28, 2005 | 05:11 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondastreet &raquo;</TD></TR><TR><TD CLASS="quote">ok, je n'ai pas réfléchie, sorry</TD></TR></TABLE>
Huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondastreet &raquo;</TD></TR><TR><TD CLASS="quote">I will buy 15x8, 5-114.3, 27 offset</TD></TR></TABLE>
Why?
Why wouldn't you go with the +45's?
And why are you set on the 15x8? What's the goal? What size tires and purpose will they be used for?
Old Jun 28, 2005 | 05:14 PM
mamaboy's Avatar
are you trying to autox? 15x8 +28 is surely going to cause rubbing....probably a badly bent fender if you even try to lower it. +28 is also going to cause more stress on your bearings. folks have to run really extreme spring rates and pull their fenders to get wheels such as the 13x8 for autoxing to fit. another factor is the sidewall aspect ratio.
Old Jun 28, 2005 | 05:26 PM
Default Re: te37 volk racing wheel (mamaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy &raquo;</TD></TR><TR><TD CLASS="quote">are you trying to autox? .</TD></TR></TABLE>
it's race car
15x8 +28 is surely going to cause rubbing....probably a badly bent fender if you even try to lower it. .</TD></TR></TABLE>
ok, i know, i will verify that.
+28 is also going to cause more stress on your bearings. folks have to run really extreme spring rates and pull their fenders to get wheels such as the 13x8 for autoxing to fit. another factor is the sidewall aspect ratio.</TD></TR></TABLE>
800 spring rate front and rear, that really extreme.
Old Jun 28, 2005 | 05:33 PM
1GreyTeg's Avatar
it's race car</TD></TR></TABLE>
Just be sure your series and class rules allow the wheels/tires to stick out past the body work.
Best of luck
gsrious
Oct 8, 2007 04:31 PM
kyeguy82
Honda Civic (2006 - 2015)
Jan 5, 2007 02:29 PM
anekin007
Jun 22, 2005 01:56 PM
Hybrid
Acura TL, RL & ZDX
Mar 30, 2004 03:58 AM
Reverend
Feb 25, 2002 09:43 AM
