b16a..obd0 question for a intake manifold....
Old Jun 28, 2005 | 03:51 PM
4DRmafia's Avatar
Default b16a..obd0 question for a intake manifold....
i was wondering and i know some b series engine parts such as intake manifold , headers, heads and etc are changeover. but my question would a gsr or type r intake manifold fit on a obd0 b16a?
Old Jun 28, 2005 | 03:57 PM
RA122324's Avatar
Yeah but they're both OBD-1 parts. Were planning to switch to OBD-1? If you weren't, you are now.
Old Jun 28, 2005 | 04:05 PM
4DRmafia's Avatar
no i am planning to stay obd0 and the reason why i ask bec i was planning to get an skunk 2 or elberock intake manifolds ....
Old Jun 28, 2005 | 04:10 PM
RA122324's Avatar
If your getting a Skunk2 or some other aftermarket manifold, you should be good. Chances are they're sold depending on application.
Old Jun 28, 2005 | 04:26 PM
4DRmafia's Avatar
do they have an application for a del sol dohc vtec? or does it matter?
Old Jun 28, 2005 | 04:52 PM
Immanuel's Avatar
Default Re: (SkipMic2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">do they have an application for a del sol dohc vtec? or does it matter?</TD></TR></TABLE>
that might work, if Iam not mistaking
Old Jun 28, 2005 | 05:36 PM
TheBobFather's Avatar
Default Re: (1.6 DOHC ED9)
GSR will not work
Type R will
Old Jun 28, 2005 | 05:46 PM
Crx Jimmy's Avatar
Default Re: b16a..obd0 question for a intake manifold.... (SkipMic2006)
you can use a type r but anything that is obd1 or2 you will also need to use a fuel rail from a obd1 or 2 because the temp sensor is in a different location in that manifold, i put aebson it had iacv holes for a typr r and stock iacv so you could use either not sure on the skunk 2 if you would have to buy a new iacv to fit that manifold
uvamosk
15
Mar 7, 2012 02:26 PM
revin=smiles
Jun 21, 2005 03:07 PM
Lamska
Sep 8, 2004 11:11 PM
91civicDXdude
May 31, 2003 05:58 AM
