MFR fix..is it worth it?
Old Jun 28, 2005 | 02:16 PM
radzer0's Avatar
Default MFR fix..is it worth it?
today i changed out my MFR to a new one i bought from acura..i figured $45+ship for new vs $30+ship for good used was better
i popped it open and its got the same dry joint i found on a tutorial thru google
who has done this and how well does it last?.. or is it just a quick fix to make it last another6 months or so?
Old Jun 28, 2005 | 04:46 PM
radzer0's Avatar
Default Re: MFR fix..is it worth it? (radzer0)
bump
Old Jun 28, 2005 | 05:27 PM
PrettyLude's Avatar
what is mfr?
Old Jun 28, 2005 | 05:30 PM
radzer0's Avatar
Default Re: (PrettyLude)
Main fuel relay
Old Jun 29, 2005 | 04:51 AM
JimBlake's Avatar
If you repair the solder joint properly, it should be real good, not a quick temporary fix. It's probably from the manufacturer trying to set up his machine to make those joints too quickly & not quite hot enough. They're not manufactured by some guy sitting at a bench making each individual joint with a soldering iron...
Old Jun 29, 2005 | 07:43 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radzer0 &raquo;</TD></TR><TR><TD CLASS="quote">
What's this dry joint your going on about?
Old Jun 29, 2005 | 09:01 AM
radzer0's Avatar
Default Re: MFR fix..is it worth it? (Chiovnidca)
http://www.markl.f9.co.uk/howt...y.htm
bottom picture
Old Jun 29, 2005 | 09:19 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radzer0 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.markl.f9.co.uk/howt...y.htm
bottom picture</TD></TR></TABLE>
That's what I call a cracked solder joint.
rasinhell
Feb 23, 2005 03:47 AM
FOrSfEd
Jan 27, 2005 07:17 AM
typeeg
Honda Motorcycles
Dec 12, 2004 11:03 AM
Drew M
21
Nov 5, 2004 08:28 AM
FredoSP
Feb 28, 2004 07:52 AM
