What axles for B16A in a 94 VX with Y21 LSD tranny? Yes searched, too many different answers
Old Jun 28, 2005 | 02:02 PM
SkoundrelUSA's Avatar
cute little bastard
Default What axles for B16A in a 94 VX with Y21 LSD tranny? Yes searched, too many different answers
Ok guys I just need to know what axles to order for my B16A SirII in my 94 VX with Y21 LSD. Please don't reply unless you are 100%. B/c I need a solid answer. Autozone guy says the part #s are different between del sol vtec and 99 Civic Si so...
UPDATE: Just so anyone who searches for this knows, I ordered 94 Del Sol axles and they fit no problems!!!
Modified by SkoundrelUSA at 3:35 PM 7/2/2005
Old Jun 28, 2005 | 02:05 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: What axles for B16A in a 94 VX with Y21 LSD tranny? Yes searched, too many different answers (Sk
94-2000 gsr will be fine
Old Jun 28, 2005 | 02:06 PM
Luserkid's Avatar
Use the Del sol.
The pass. side integra axle needs to be shortened in order to work.
Old Jun 28, 2005 | 06:23 PM
cute little bastard
one more time
Old Jun 28, 2005 | 08:04 PM
jdmsiR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">94-2000 gsr will be fine </TD></TR></TABLE>
Old Jun 28, 2005 | 08:09 PM
unite's Avatar
I've got an LS swap in my ej2 and i'm using 94-01 LS axles. I would assume in your case you would use 99-00 Civic SI axles.
Old Jun 28, 2005 | 08:10 PM
JDMisGOOD's Avatar
94-01 Integra axles
Old Jun 28, 2005 | 09:06 PM
kaiba's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">94-01 Integra axles </TD></TR></TABLE>
Old Jun 29, 2005 | 02:47 AM
DeadVet's Avatar
94-01 integra axles, del sol with b16 axles, 99-00 axles.
Old Jun 29, 2005 | 04:27 AM
dwnthehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1TurboHatch &raquo;</TD></TR><TR><TD CLASS="quote">94-01 integra axles, del sol with b16 axles, 99-00 axles. </TD></TR></TABLE>
Old Jun 29, 2005 | 04:34 AM
cute little bastard
I heard that the length one 1 could be too long... Are you guys positive?
Old Jun 29, 2005 | 01:58 PM
DeadVet's Avatar
well yes im positive. IM using a 99-00 axle and a del sol axle and i have a friend who is using integra axles so yes all 3 work.
Old Jun 30, 2005 | 05:25 AM
boostmywankle's Avatar
same here
Old Jun 30, 2005 | 06:08 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Ok guys I just need to know what axles to order for my B16A SirII in my 94 VX with Y21 LSD. Please don't reply unless you are 100%. B/c I need a solid answer. Autozone guy says the part #s are different between del sol vtec and 99 Civic Si so...</TD></TR></TABLE>
Passenger side axel:
99-00 civic SI
94-97 Del slow Vtec
90-01 INTEGRA RS/GS/LS/GSR/ITR(us only)
Drivers side axel:
if you have 90-93 haft haft
90-93 integra any model
if you have 99-00 si haftshaft/ 94-01 gsr/itr/ls/gs/
94-97 del slow vtec halfshaft
you need
94-01 INTEGRA, 94-97 del slow vtec 99-00 civic si
ABS DOES NOT MATTER...
you can run abs axels in a non abs car!!
Old Jun 30, 2005 | 06:10 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
The pass. side integra axle needs to be shortened in order to work. </TD></TR></TABLE>
<U>WRONG INFO!!!!!!!!!!! KNOW BEFORE YOU POST WRONG info!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!IDIOTS </U>
Old Jun 30, 2005 | 06:54 AM
cute little bastard
Does anyone know what half shaft a JDM B16A is equivalent to?
Old Jun 30, 2005 | 07:25 AM
Dancing is Forbidden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Use the Del sol.
The pass. side integra axle needs to be shortened in order to work. </TD></TR></TABLE>WHAT THE HELL are you talking about?
Old Jun 30, 2005 | 07:35 AM
cute little bastard
Well the part #s on hondaautomotiveparts.com don't match between EM1 axles and del sol VTEC axles...
Old Jun 30, 2005 | 07:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Well the part #s on hondaautomotiveparts.com don't match between EM1 axles and del sol VTEC axles...</TD></TR></TABLE>LISTEN DAMNIT. Chad and I have done plenty of swaps into EG's and you can use either or or mix and match. It doesnt realy matter. Both produce the same result, getting power to your wheels.
Old Jun 30, 2005 | 07:50 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know what half shaft a JDM B16A is equivalent to?</TD></TR></TABLE>
depends on if you got a 1st gen b16 or a 2nd gen....
part numbers for del slow vtec and em1 should be the same for the half shaft....if not they ARE THE SAME....honda might have changed a bearing or something but they are the same and will work the same way
Old Jun 30, 2005 | 07:52 AM
cute little bastard
its 2nd gen
Old Jun 30, 2005 | 07:55 AM
IM taking care of this Chadwick.
Old Jun 30, 2005 | 08:39 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ih8jdm &raquo;</TD></TR><TR><TD CLASS="quote">IM taking care of this Chadwick.</TD></TR></TABLE>
bring me food homo
Old Jun 30, 2005 | 08:55 AM
Well If I had an engine in my CRX I might. Where's papa at today?
Old Jun 30, 2005 | 09:00 AM
m1cheln4v4rro
Jul 12, 2012 07:24 PM
DelSolMarine
Sep 11, 2006 08:36 AM
DelSolMarine
Apr 26, 2006 04:42 PM
EG93si
Mar 8, 2006 09:23 PM
upstate
Jun 23, 2004 10:12 AM
