!@#$%^&* come and get it *&^%$#@!
Old Jun 28, 2005 | 02:02 PM
RACINTWEEK's Avatar
Default !@#$%^&* come and get it *&^%$#@!
***This thread will updated constantly***
For sale in Arlington VA 22204
**will not ship anything large or heavy**
if you have any questions PM with my description of the part so i know what you are talking about
all prices are OBO. i'm not a ********, i know what its like to be broke
i will accept trades for b-series turbo parts
i accept Paypal and USPS money orders only for my security and yours
i have sould to a couple guys on here and i have plenty of vouches on homemadeturbo.com under same SN: Racintweek
e-mail: racintweek@hotmail.com
D16A6 shortblock w/ pistons, rods, crank, oil pan, and misc other parts. has very light surface rust on cyl walls from being on my balcony, quick hone is all it needs $125
D16A6 rebuilt head, zero miles- new valve seals, valves lapped in. comes with partially stripped valve cover i was going to repaint. no dizzy. $125
D16A6 intake manifold w/ throttle body, fuel rail, IAT, and IACV $50
D16A6 L3 Si trans- was re-built ~25k mi ago. great condition other than oil on case from horrible valve cover leak. ****soldd****
CRX Si front sway bar W/ poly end links- $30
90 CRX Driver side door glass- $30
CRX Si rear storage compartment- decent condition, needs to be cleaned. $50
CRX Si door panels- OK condition. $50/both
CRX Si black dashboard w/ audio/shifter console and glove box. 8 out of 10 condition, broken clip on center vent, no cluster hood $100
CRX Si flywheel- $20 or $10 w/ engine or trans
CRX Si exhaust mani and down pipe- $25 ****PENDING****
CRX Si engine mounts- all 4-$30, seperate $10ea
PM6 Dizzy- coil messed up, good for core $15
CRX Si stock springs and shox, still assembled- all 4=$50 or $15ea ***PENDING***
1G CRX Si new valve cover gasket- $10
1G CRX SI "Phone Dial" wheels 14", good cond. *******SOLD************
90-93 LS new thermostat- $15
92-93 OBD1 LS engine harness, only missing temp sensor plug- $40
88-91 DPFI new dizzy cap & rotor- $20
KKK K03S Jetta 1.8t turbo ~25k mi, very little shaft play $50
Turbonetics T3 5bolt DP- 2.5" just needs flex pipe $50
T3/T4 rebuild kit- dynamic seal, 270* $75
Garrett 3 bolt wastegate housing, brand new- $25
T3 wastegate actuator- $15 or $10 w/ housing
Dodge Shadow 42/48 T3, needs rebuild- $30
+++++++++NEW STUFF++++++++++ added 28 June @ 12:15pm
90-93 LS new timing belt- ****sold****
90-91 LS new alternator belt- $10
90-93 LS exhaust mani heat shield- $10
2002 Jetta 1.8t SMIC- $50
AFP VR6 longblock, 30K mi- needs rod bearings, good compression. lots of misc parts included- ++will part out if price is right++ PM for details $250
Dewalt Sawz-all- used to destroy my old CRX, perfect working cond, incl case
paid ~$130- asking $90
set of Jetta/GTi 1.8t pistons, 3 used in good cond, 1 brand new- $75
MK4 AEG 2.0 Cyl head- lots of misc parts incl- PM for details- $100
____________even more new stuff_______________ added 28 June @ 1:30pm
VW MKII banana lights, 2 sets- $15/set or $25 for both sets
Summit Battery relocation kit, never installed- ***sold***
&&&&&&&&_yup more stuff_&&&&&&&&&&&&&& added 28 June @3:35pm
B-series piston rings, 81mm bought from olympic never used- **sold**
2 black steelies- 4X100 14x6 et38, need tires- $25ea or $40 both
2 silver steelies- 13x? , standard honda steelies, need tires $15ea or $25 both
2.25" glasspack resonator- ~31" long, brand new-$25
$$$$$$$$$_you guessed it_$$$$$$$$$$$$$$ added 28 June @ 5:02pm
V-belt- Kelly Springfield #17375, 1.3cm x 95.5cm, brand new-$10
V-belt- Kelly Springfield #13250, 1cm x 63.5cm, brand new-$10
VW 2.0 ABA, lower intake mani gasket, pn: 037-129-717-c $10
set of tire chains, for 2 tires up to 195-60-14, $25
CRX Si center caps, could use some paint- $25
10 cans of **** brown spray paint-$15
1980-92 VW Vanagon-driverside smokers window, green, new in box-
pn: 253-845-247-a - $50
^^^^^^^ a little more^^^^^^^ added 28 June @ 5:58pm
VW MKII Digi2, fuel pump relay pn:191-906-383-c - $10
VW MKII, lower rad hose, pn: 191-121-051-p -$15
VW MK4 TDI, turbo > DP gasket, pn: 3a0-253-115 -$20
VW MKII & MKIII A/C thermal switch, pn:357-919-369-e
(((((((((((((((((((__MORE__))))))))))))))))))))))) ))))))))))))
flywheels, 1 D-series & 1 B-series- $20ea
d-series starter-$25
((((((((((((((((((((more stuff))))))))))))))))))))))
MKII small bumper lower grille- new one $30, used one $15
***********MUCH MORE TO COME*************
++++++++++++STAY TUNED++++++++++++
as you can see i have a bunch of random ****, dont hesitate to ask if you dont see it
Modified by RACINTWEEK at 1:22 PM 7/11/2005
Old Jun 28, 2005 | 02:31 PM
RACINTWEEK's Avatar
Default Re: !@#$%^&* come and get it *&^%$#@! (RACINTWEEK)
this thread doesnt belong on page 2
Old Jun 28, 2005 | 06:26 PM
RACINTWEEK's Avatar
yup
Old Jun 28, 2005 | 07:56 PM
RACINTWEEK's Avatar
more stuff added
Old Jun 29, 2005 | 02:24 AM
RACINTWEEK's Avatar
bump for edit
Old Jun 29, 2005 | 05:18 AM
RACINTWEEK's Avatar
Old Jun 29, 2005 | 07:08 AM
RACINTWEEK's Avatar
update
Old Jun 29, 2005 | 03:23 PM
RACINTWEEK's Avatar
hello
Old Jun 30, 2005 | 07:45 AM
RACINTWEEK's Avatar
UPDATE
Old Jun 30, 2005 | 04:13 PM
RACINTWEEK's Avatar
up
Old Jul 2, 2005 | 10:35 AM
RACINTWEEK's Avatar
up
Old Jul 4, 2005 | 05:26 AM
RACINTWEEK's Avatar
updates
Old Jul 11, 2005 | 07:59 AM
Em1guy's Avatar
i want parts
Old Jul 11, 2005 | 09:19 AM
RACINTWEEK's Avatar
Default Re: !@#$%^&* come and get it *&^%$#@! (Em1guy)
pm replied
Old Aug 8, 2005 | 06:48 PM
ooairewreckoo's Avatar
great seller... bump
Old Aug 29, 2005 | 06:02 AM
Em1guy's Avatar
Default Re: !@#$%^&* come and get it *&^%$#@! (ooairewreckoo)
hey give me i a call i finally have a place to put that vr if you still have it? pm me with your number and i will call you if so
Old Aug 31, 2005 | 06:37 AM
Jesterian's Avatar
24.243.141.75
You wouldn't happen to have the optional cigarette lighter for my 90 civic std?
Old Oct 1, 2005 | 06:32 PM
tur3oDC4's Avatar
Default Re: !@#$%^&* come and get it *&^%$#@! (Jesterian)
bump
gc92cvc
Northeast (Sales)
12
Dec 8, 2009 08:19 AM
thurmondauto
Southeast (Sales)
13
Jul 5, 2009 09:20 AM
thurmondauto
Jun 29, 2009 11:56 AM
Cprace1
Jul 13, 2006 10:24 AM
RACINTWEEK
Mid-Atlantic (Sales)
Jul 28, 2005 07:35 AM
