CEL: 9 CYP - cylinder sensor
Old Jun 28, 2005 | 01:20 PM
athoughts's Avatar
Default CEL: 9 CYP - cylinder sensor
Hey, my CEL would come on and off during idle of my car, the code it would throw was 9.. This last few days my CEL has been always on, i do not believe it is the same code..
is there a way to check for more than 1 code being thrown?
Any info on CEL 9?!
thanks!
Old Jun 28, 2005 | 02:18 PM
EE_Chris's Avatar
Default Re: CEL: 9 CYP - cylinder sensor (athoughts)
When you initially checked the codes and got 9, if the ECU had stored more than one code, it would have spit it out at you either before or after (depending on which number it is) it did 9.
Did you check for obvious broken wires? Have you removed the distributor cap to check for anything amiss?
There is a thread at the top of this page concerning codes. There is also the search button.
Do you have a Helms? Do you have a meter to do some electrical checks on that sensor?
That sensor is located in the distributor. If its bad, you have to replace the entire distributor sub-assembly. Costs about $275 from places like slhondaparts.com.
Old Jun 28, 2005 | 02:27 PM
athoughts's Avatar
Default Re: CEL: 9 CYP - cylinder sensor (EE_Chris)
yeah thanks for the info, imma pull it part today
Old Jun 28, 2005 | 02:56 PM
athoughts's Avatar
will i be harming anything driving like this.. until i have the money to replace it?
Old Jun 28, 2005 | 05:13 PM
athoughts's Avatar
Old Jun 28, 2005 | 08:44 PM
athoughts's Avatar
up
Old Jun 28, 2005 | 10:27 PM
vg7z's Avatar
i had CYP sensor like a month ago. i replaced my dizzy rotor and used hella force. i guess i fucked up a sensor. i ran it like this for a month, the CEL would randomly go on, the car ran fine but i just changed the dizzy cuz i really need my car to be reliable
Old Jun 30, 2005 | 06:59 PM
athoughts's Avatar
Default Re: (vg7z)
Yeah i will probably be driving like this for awhile until i have the funds to replace it
Old Jun 30, 2005 | 09:18 PM
Airbag Club's Avatar
Default Re: (athoughts)
is it 9 long blinks, or 9 short blinks? if it is 9 short blinks, it is the CYP sensor, which can be fixed by changing dizzy's. if it is 9 long blinks, it is actually code 90, which is evap canister..
Old Jul 1, 2005 | 11:55 AM
athoughts's Avatar
Default Re: (Airbag Club)
uhh yeah its code 9.
Old Jul 2, 2005 | 11:24 AM
athoughts's Avatar
yeah a full new dizzy is gonna cost $320 or soemthing from auto zone.. How hard and expensive is just replacing the sensor? or can you not just replace that?
Old Jul 2, 2005 | 12:19 PM
athoughts's Avatar
Old Jul 3, 2005 | 10:16 AM
athoughts's Avatar
the new dizzy is on order, we will see if it fixes it..
thanks
*HandGrenadeEK*
12
Mar 12, 2012 03:50 PM
MumBleZ_94gsR
Sep 1, 2009 05:30 AM
Topshot
Oct 8, 2007 04:13 PM
athoughts
May 28, 2005 10:31 AM
