throw out bearing sqealing
Old Jun 28, 2005 | 08:44 AM
pa2play's Avatar
Default throw out bearing sqealing
I just changed my clutch and throw out bearing and now when idleing out of gear it sounds like my throwout bearing it making noise, then when I put a little pressure on the clutch, it goes away. I greased the throwout bearing, maybe not enough, any ideas?
Old Jun 28, 2005 | 09:01 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: throw out bearing sqealing (pa2play)
<---same exact problem...
Old Jun 28, 2005 | 09:21 AM
MonkeyBoy668's Avatar
I believe the rule of thumb is that if it's making noise with the clutch pedal depressed it's the throwout bearing, if it's making noise with the clutch pedal released then it's either the input shaft bearing or the engine side bearing - normally the ISB.
Or, at least, that's what someone screamed at me last time I put my nose into one of these discussions - so YMMV.
Old Jul 28, 2005 | 09:42 AM
jazz1320's Avatar
Default Re: throw out bearing sqealing (MonkeyBoy668)
when i drive and hit the clutch ihear it
TOO MUCH TORQUE
Oct 3, 2015 10:20 PM
dwils
Mar 5, 2011 12:24 PM
93 EG
12
Mar 3, 2007 08:14 AM
Aron Parsons
Mar 6, 2006 09:18 PM
