h22a4 head on h23 block
Old Jun 28, 2005 | 08:09 AM
darkspector's Avatar
Default h22a4 head on h23 block
will the newer h22 head work on my 92 si h23? will the odb2 mess it up? or will I have to convert? I found an usdm h22a4 with "one cylinder with low compression" for $650 sounds like a good deal for something that could only be a ring or something. he said it'll still run also it's in the car now. what ya think?
Old Jun 28, 2005 | 08:15 AM
Sam1am26's Avatar
Default Re: h22a4 head on h23 block (darkspector)
Yes it will work... You will want to use OBD1 injectors though with a P13 OBD1 ecu... You can reuse your H23 distributor...
Old Jun 28, 2005 | 11:50 AM
Default Re: h22a4 head on h23 block (Sam1am26)
can I use my h23 injectors? or are they too small? and i guess i just don't need to hook up the other obd2 sensors if there are any
Old Jun 28, 2005 | 12:14 PM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkspector &raquo;</TD></TR><TR><TD CLASS="quote">can I use my h23 injectors? or are they too small? and i guess i just don't need to hook up the other obd2 sensors if there are any</TD></TR></TABLE>
No, you will need OBD1 H22 Injectors because yes, the H23 ones are too small... And there aren't any OBD2 sensors on the head for you to worry about....
Old Jun 28, 2005 | 12:49 PM
mkay that's awesome i'm gonna see if I can get that deal... sounds pretty sweet! although I should probably get my block rebuilt first i'm coming up on 190k
Old Jun 30, 2005 | 07:14 AM
if i'm gonna take the head off, what else can I do while the head is off to rejuivinate things. I should probably get some piston rings cuz my current engine has 190k on it. Is it possible to replace main bearings while the block is still in the car?
Also... so I just throw the head on, or should I clay it or what not? The guy is gonna give me the h22a4 for $450 so i'm gonna take it.. that's a lot of spare parts
Old Jun 30, 2005 | 08:46 AM
Sam1am26's Avatar
No need to clay it if you are using H23 pistons still... but at 190k I would suggest a full rebuild... Replace all bearings and rings... And if you have the money maybe see if you can get some higher compression pistons...
Old Jun 30, 2005 | 01:47 PM
yeah, i was gonna see if the pistons in the motor i'm getting will fit. so I can at least have around 10:1 compression. and I was more than definately gonna do rings, and is it possible to replace the bearings with the block in the car still? i'm gonna need to do this in a weekend though... cuz of work and all, maybe take one day off. Now to do a hone? do you need a special honer, or will any honer work. Sorry if these are stupid questions.
Appreciate the help though,
-Chris
Old Aug 4, 2005 | 11:04 AM
IAluder95's Avatar
bringing it from the dead.
so did you get this done? i was going to take the H22a4 head i found and make an H23aVtec with it.
plus what tranny are you using?
Old Aug 4, 2005 | 11:09 AM
high_revs's Avatar
yes you can do man and rod bearings while the block is in the car and deff. get some higher compression pistons because with the h22 head with the h23 pistons your compression will be like 9.3:1 which is garbage for an all motor setup.
Old Aug 4, 2005 | 12:50 PM
IAluder95's Avatar
i was going to boost it so the 9.3 is better.
but i have read on how to this many times.
i plan to build the motor and block then put it together.
balliso911
Jul 13, 2010 07:07 PM
92hondalude
Nov 28, 2006 06:04 AM
JDMnatic
Feb 9, 2005 05:06 AM
HYBRIDJDM WAGON
Jul 5, 2003 06:43 PM
littleredhatch
Dec 5, 2002 05:49 AM
