HEAD UNIT INSTALLATION PROBLEMS
Old Jun 28, 2005 | 07:11 AM
nyjets05's Avatar
Default HEAD UNIT INSTALLATION PROBLEMS
I want to install my head unit on my 98 civic ex coupe, but I hear there is controversy in both locations. If I install it in the dash, I was told keyless entry would be disabled. I do not want to lose keyless entry. How do I install the unit so that I keep my keyless entry?
Also I could install it behind the shifter under the dash. But I was told the wires from the current unit arent long enough. what wires would I need and how does it connect? Also would that disable the keyless entry anyway if you are taking the car wires from the stock unit and connecting them to a wiring harness for the aftermarket unit below?
Any help is appreciated....I refuse to let best buy or circuit city charge me a fortune for what should be a simple job.
Old Jun 28, 2005 | 07:17 AM
saxqtzk's Avatar
Default Re: HEAD UNIT INSTALLATION PROBLEMS (nyjets05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyjets05 &raquo;</TD></TR><TR><TD CLASS="quote">I want to install my head unit on my 98 civic ex coupe, but I hear there is controversy in both locations. If I install it in the dash, I was told keyless entry would be disabled. I do not want to lose keyless entry. How do I install the unit so that I keep my keyless entry?
Any help is appreciated....I refuse to let best buy or circuit city charge me a fortune for what should be a simple job.</TD></TR></TABLE>
The wires are long enough if you decided to move the headunit where the shifter is that's assuming you're using a metra harness or splicing and extending the wires.
If you want to maintain the keyless entry (module built in with the stock radio) click this link:
http://www.installdr.com/Insta...3.pdf
By the way, if you have more questions about this try the security/audio section on the forum.
AUD1OSlave
Jun 10, 2009 02:56 PM
EXrated
Audio / Security / Video
Aug 24, 2005 12:42 PM
skiwithcars
Apr 23, 2005 09:01 AM
rossockr
Mar 21, 2003 09:53 PM
rossockr
Mar 17, 2003 06:23 PM
