buddy club 3+ cams, hard to tune?
Old Jun 28, 2005 | 02:44 AM
an2ny888's Avatar
Default buddy club 3+ cams, hard to tune?
just installed my bc3+ cams in my jdm b18cr swap. i'm scheduled to dyno in a month, so currently they're at 0,0. i heard these cams are supposed to be drop in and go, so they shouldn't require too much tuning. they feel really strong when the engine is not fully warm, but once the car is hot, they feel weak, like the engine is strangled. do the bc's really suck when they're untuned? i had spoon cams before, those felt great even when they were still untuned
Old Jun 28, 2005 | 03:11 AM
Misfit's Avatar
Default Re: buddy club 3+ cams, hard to tune? (an2ny888)
There are no drop in a go cams.
what header are you going to be using? A header will make day and night difference.
Are you using stock valve train?
Old Jun 28, 2005 | 03:14 AM
an2ny888's Avatar
Default Re: buddy club 3+ cams, hard to tune? (Misfit)
i'm using maxim works (same as jun) 4-2-1 headers. just can't understand why they perform better when the engine isn't hot yet. yeah i'm using itr valvetrain
Old Jun 28, 2005 | 04:30 AM
acuracy r's Avatar
at least with mine, they didnt do that good drop in and go. Only after some street tuning did they start to pull nice. Also, with those cams at 0,0, they midrange isnt really there. Once you start advancing the intake and retarding the exhaust, the midrange should wake up, and youll be happy
Old Jun 28, 2005 | 04:42 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">just installed my bc3+ cams in my jdm b18cr swap. i'm scheduled to dyno in a month, so currently they're at 0,0. i heard these cams are supposed to be drop in and go, so they shouldn't require too much tuning. they feel really strong when the engine is not fully warm, but once the car is hot, they feel weak, like the engine is strangled. </TD></TR></TABLE>
Where did you get the idea they wouldn't need tuning? I don't think that's a good idea at all.
It's probably safe to move the car around at 0,0 and no tuning, but I certainly wouldn't engage in any kind of enthusiastic driving at alll.
What other modifications have you made? Fuel pressure? Injectors? What computer are you using, and what kind of fuel map and spark advance is currently installed?
It's possible the car is leaning out dangerously in some situations, so please consider not doing any enthusiastic driving until the car is tuned.
Old Jun 28, 2005 | 04:44 AM
acuracy r's Avatar
Default Re: buddy club 3+ cams, hard to tune? (George Knighton)
This is true, when we first dropped them in and datalogged, we have to add a good amount of fuel to the entire powerband. This was with uberdata btw
Old Jun 28, 2005 | 06:30 AM
Misfit's Avatar
Default Re: buddy club 3+ cams, hard to tune? (acuracy r)
It sounds like you are trying to cheap your way around this...
Do not slack on anything unless you like dropping thousands of dollars on rebuilt motors.
And get a good EMS... and put back in the stock cams till you can afford to do the job right the first time...
ask me how I know
Old Jun 28, 2005 | 06:43 AM
jdmjunky's Avatar
is the ITR valvetrain enough to handle the BC IIIs? i'd always thought that they were quite aggressive. the last thing u would want is valve float, among other problems...excited to see the difference once they're tuned though.
good luck with it
Old Jun 28, 2005 | 07:35 AM
HondaRcB's Avatar
Default Re: buddy club 3+ cams, hard to tune? (jdmjunky)
Mine felt really flat when ran untuned on the stock ECU. Once tuned with Hondata and the cam gears the car really came to life. Most of the power was found from advancing the timing and adjusting the cam gears. Fuekl was also added everywhere, and with stock fuel injectors and FPR I ran out of injector at 6200rpm. Good luck.
Old Jun 28, 2005 | 08:03 AM
an2ny888's Avatar
Default Re: buddy club 3+ cams, hard to tune? (HondaRcB)
ok will get it tuned asap, tnx for the replies
Old Jun 28, 2005 | 08:15 AM
ITRacer121's Avatar
it is not a hard cam to tune but it does NEED to be tuned
I also would not expect super high peak on the dyno
these are a great mid range cam
Old Jun 28, 2005 | 08:22 AM
Bbasso's Avatar
make sure the stock valvetrain can handle the lobes and rpm.
Old Jun 28, 2005 | 03:15 PM
acuracy r's Avatar
Default Re: buddy club 3+ cams, hard to tune? (Bbasso)
stock itr valvetrain will do just fine. i went with portflow inners for added protection, i guess its a judgement call...
Old Jun 28, 2005 | 03:43 PM
Misfit's Avatar
actually you should really use what the manufacturer suggests... really there is no judgement call necessary.
I personally would rather be safe than sorry.
Old Jun 28, 2005 | 03:59 PM
HondaRcB's Avatar
Stock valvetrain here. So good so far.
Old Jul 26, 2005 | 04:17 PM
ultimatehonda's Avatar
I also just installed a set of these cams. Everyone says to advance the intake cam to +2 and leave the exhaust at 0? I really havent felt any power on these either. I need to get a wideband to see whats up with the air/fuel.
Old Jul 26, 2005 | 05:15 PM
HondaRcB's Avatar
Default Re: buddy club 3+ cams, hard to tune? (ultimatehonda)
Do a search. I have a rather legnthy post on the topic.
Old Aug 2, 2005 | 06:01 AM
fracas's Avatar
I just sold a set of skunk2 stage 1 cams and bought a set of BCIII+'s. Now I noticed a big difference in the Mid range after the Install. I will be getting tuned later this week. Im so ready to see how this cams preform.
Old Aug 3, 2005 | 04:46 AM
jeremy.'s Avatar
Default Re: (fracas)
stock itr valvetrain is fine....i've heard they are a really easy to tune. i have my intake advanced +2....midrange is awesome but defintely not a drop and go cam
Old Aug 3, 2005 | 05:04 AM
LUCKY CHARMS's Avatar
Default Re: (ekay_jeremy)
i'm playing with the idea at the moment, spec III or spec IV?? spec IV needs quite a bit of work, how big an increase are specIII over ITR cams, i'd like your opinion on everyday use, thanks
Old Aug 3, 2005 | 08:28 AM
.water's Avatar
ya stock ITR valve trains will do just fine. even stock GSR valve trains are fine.
and setting on 0 does not do any good. just set them to right number. dont need to tune fuel or anything. from what i know.
And SEARCH
https://honda-tech.com/zero...age=4
Old Aug 3, 2005 | 01:28 PM
dnatrance's Avatar
Default Re: buddy club 3+ cams, hard to tune? (R81-00-DC2)
whats the right number?
Old Aug 3, 2005 | 02:03 PM
GUILOTINE's Avatar
Kill Gil
Call Shaun Church and he'll tell you the most common settings he leaves them at. He knows his ****
310-713-6171
Old Aug 3, 2005 | 04:57 PM
an2ny888's Avatar
Default Re: (GUILOTINE)
i wish i could call him up, unfortunately i'm in asia, phone charges would be huge
px_R
Sep 10, 2006 10:55 AM
theblkrascal
Honda Civic (2001 - 2005)
10
Aug 31, 2006 03:15 PM
DA-9mordef
Apr 27, 2006 10:04 AM
BlackRocket
18
Nov 9, 2004 05:19 PM
