car won't start HHHEEELLLPPP
Old Jun 27, 2005 | 09:40 PM
91d15bvtec's Avatar
Default car won't start HHHEEELLLPPP
my crx still won't start. no priming of the fuel pump. i took the main line at the rail off and no fuel came out after a few cranks. tried a new main relay. checked fuses and tried another ecu. still nothing. came home from work turned off. then tried to start and thought i was maybe out of gas. 2 gallons of fuel then no start. next morning starts right up. then after day in the sun no start. tried new ecu and main relay still nothing.
any suggestions appreciated.
Old Jun 28, 2005 | 05:34 PM
PrettyLude's Avatar
Default Re: car won't start HHHEEELLLPPP (91d15bvtec)
check to see if your fuel pump even works
Old Jun 28, 2005 | 06:11 PM
slomofo's Avatar
GDD Member
Default Re: car won't start HHHEEELLLPPP (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">check to see if your fuel pump even works</TD></TR></TABLE>
Check main relay if fuel pump is good.
Old Jun 29, 2005 | 05:08 PM
kidrolla's Avatar
Default Re: car won't start HHHEEELLLPPP (slomofo)
do you hear your fuel pump kick on
Champs32
15
Aug 30, 2010 02:17 PM
thatEFboy
Aug 25, 2008 02:14 PM
Si-Samuri
29
Jun 19, 2008 05:48 PM
91d15bvtec
Jun 28, 2005 01:42 PM
areyouahobo
Jul 3, 2003 05:39 AM
