cluster help
Old Jun 27, 2005 | 08:38 PM
LudeJdm's Avatar
Default cluster help
hey everyone juss swapped out my 88 hatchback dx w/o tach cluster with an 89 crx si w/tach cluster....only problem is that the fuel gauge isnt working and the temperature gauge...any idea whats wrong....do i have to move some wires around or something???? help please....thanks in adavance
Old Jun 27, 2005 | 08:48 PM
LudeJdm's Avatar
Default Re: cluster help (envysionHATCH)
or those it take a while for the fuel gauge to go up????
Old Jun 27, 2005 | 08:50 PM
bagpipe goatee's Avatar
it takes a little while, like a minute on my car, not a huge amount of time, if you drove with it you'd definitely see it go up.
Old Jun 27, 2005 | 10:54 PM
LudeJdm's Avatar
Default Re: (bagpipe goatee)
ok ill check it out tomorrow....ill drive it around tomorrow.....
Old Jun 27, 2005 | 10:59 PM
FaceTuned's Avatar
your fuel gage wire is the yello/white and the temp is yellow/green switch the wires around see if the gas goes up and the temp takes a lil while cuz right now it sounds like the gas is switch with the temp but i could be wrong good luckk
Old Jun 27, 2005 | 11:06 PM
LudeJdm's Avatar
Default Re: (jdmhatchness)
which plug r these wires in???
Old Jun 28, 2005 | 10:03 AM
LudeJdm's Avatar
Default Re: (envysionHATCH)
ok...still doesnt work....after a few minutes of driving the hot/cold gauge rises just a lil bit...but the gas doesnt rise at all....also the rpm gauge....bounces up n down....also my hi-beam indicator doenst light up....still need help....
Old Jun 28, 2005 | 10:41 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envysionHATCH &raquo;</TD></TR><TR><TD CLASS="quote">ok...still doesnt work....after a few minutes of driving the hot/cold gauge rises just a lil bit...but the gas doesnt rise at all....also the rpm gauge....bounces up n down....also my hi-beam indicator doenst light up....still need help....</TD></TR></TABLE>
the tach bouncing is either the dizzy or the ignitor going bad. its a common thing. you do have enough gas to move the needle up yeah? also do the hi beams actually work or just the indicator not working?
Old Jun 28, 2005 | 10:48 AM
LudeJdm's Avatar
Default Re: (APEX CRX)
the indicator isnt working.....
Old Jun 28, 2005 | 10:57 AM
APEX CRX's Avatar
pull out the bulb and make sure the base is making good contact, if it is take out one of your old bulbs from your other cluster and just replace it to see it was just the bulb since your high beams actually work
Old Jun 28, 2005 | 11:07 AM
LudeJdm's Avatar
i found a blue socket to plug in another plug in the si cluster but my hatch doesnt have an extra plug for it....
Old Jun 28, 2005 | 11:10 AM
APEX CRX's Avatar
hmm. I really can't say/know anybody know what the blue plug in the center of the cluster is for?
Old Jun 28, 2005 | 11:48 AM
LudeJdm's Avatar
still need help.....what is the blue plug for??? and how come my temp and fuel gauge isnt working???i thought it was straight foward plug n play.....
Old Jun 28, 2005 | 12:28 PM
FaceTuned's Avatar
is that guage cluster any good
Old Jun 28, 2005 | 12:51 PM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatchness &raquo;</TD></TR><TR><TD CLASS="quote">is that guage cluster any good
?</TD></TR></TABLE>
Yeah it is, he bought it from me and I pulled it out of my CRX this past weekend
I searched and saw a few thread about putting in an Si cluster in a DX abd some say its plug and play and some say it isn't?
Old Jun 28, 2005 | 02:10 PM
APEX CRX's Avatar
BUMP
Old Jun 28, 2005 | 07:36 PM
LudeJdm's Avatar
still need help....fuel n temp gauge also hi-beam indicator not lighting up....
Old Jun 28, 2005 | 10:28 PM
LudeJdm's Avatar
any ideas !!!!
Old Jun 29, 2005 | 07:25 PM
LudeJdm's Avatar
bump!!!
Old Jul 3, 2005 | 05:46 PM
LudeJdm's Avatar
delete post solved problem
seth01tuner
Oct 19, 2014 05:19 PM
efstunnin
20
May 29, 2012 02:27 PM
zxpher1
Aug 25, 2009 06:30 PM
traxxasx
Mar 9, 2008 08:23 PM
