automatic to manuel
ok...i have a 97 civic ex,all i knoe is i need a clutch pedal, ecu, and clutch lines...im doin a full motor swap but i need to knoe wat will i need exactly to change from automatic to manuel?
welcome to honda-tech, this subject is covered in great detail,
in brief,
1. Manual Tranny with the fork and pilot bearing and flywheel cover. (I gotta LS for my turbo setup)
2. Clutch with pressure plate (I gotta Clutch Master from Ultrarev.com $409)
3. Flywheel (I gotta Clutch Master from Ultrarev.com $187)
4. All flywheel and pressure plate bolts (automatic ones are different)
5. Manual Starter with the 2 bolts (one long and one short)
6. Front tranny mount
7. Manual Rear support bracket (the one in the back that connects the tranny and the block)
8. Manual Front Tranny mount (it's the arm with 3 holes in it, the automatic is different)
9. Upper Tranny Conversion mount (I got mine from Hasport for $175, its a must, unless you want to modify
a stock manual mount. The automatic mount will not fit.)
10. clutch pedal (brake and gas are optional, I just cut my brake smaller and got
covers for the pedals. looks alright.
11. clutch master with clutch reseviour
12. slave cylinder
13. hard clutch lines going from clutch master to slave cylinder
14. soft clutch line between the hard clutch lines and slave cylinder
15. shift linkages with the pin and clamp for the shifter and
the 2 washers and bolt that support the stablizer
16. shifter
17. shift **** (skunk2)
18. manual shift console with shift boot
19. Everyone says that you need manaul axels and intermediate shaft, but
I was able to get away with using my automatic ones. But if you're not sure
get the manual ones. I wasn't sure either, but I had a set when I bought the tranny.
20. Optional Manual ECU. I bought one, but didn't use it becuase the wiring harness is different
for automatics. My automatic one works just fine.
21. All the nuts and bolts to bolt in the new parts. Look on http://www.acuraautomotiveparts.org/ to see what you need.
You're probably going to need all the tranny bolts, the three bolts for the front tranny mount,
the starter bolts, the shift linkage bolts, flywheel, and pressure plate bolts, also optional is
the silver arm that connects the tranny and block from the bottom. the automatic one is different.
22. Crucial tools: Something to cut metal,breaker bar, drill,and torque wrench for flywheel and pressure plate (19 lbs)
I was able to do the swap with a 137 piece crafsman tool set. You'll also need some sheet metal.
please search "auto the manual" and you will get all the knowledge you need. Anymore questions feel free to im me, but study first if you don't mind.
in brief,
12. slave cylinder
16. shifter
https://honda-tech.com/zerothread?id=1124272
https://honda-tech.com/zerothread?id=550221
Manuel is a man's name
AznInvasion
Sep 12, 2003 06:19 PM
