Rear Deck Rattles
Old Jun 27, 2005 | 04:29 PM
sportsfreak5's Avatar
Default Rear Deck Rattles
i just put a sub in my 98 civic and the rear deck rattles like crazy. i have dampened the trunk, but i dont know if i should dampen underneath the deck-salesguy told me u cant prevent plastic from rattling. Any suggestions?
Old Jun 27, 2005 | 04:52 PM
TsukubaDreams's Avatar
Default Re: Rear Deck Rattles (sportsfreak5)
get some of that stuff they put on the back of cabinets to prevent it from slaming hella hard, you can get it at home deopt, and put it on the bottom of it. Its like this tape looking stuff and its about 1/8 in thick foam pad with one sticky side.... or just take it out all together.
Old Jun 27, 2005 | 05:08 PM
pdiggitydogg's Avatar
Crawl in your trunk. Look at the bottom of the deck - see the big holes? Shove socks in there, to push the plastic cover up.
Done Free Works great
Old Jun 28, 2005 | 06:34 AM
rewhipple's Avatar
i have the same problem but the rattling sounds like it is coming from my 60/40 split seat. haven't had the time to sit down and try and track the sound but that might be another place to look.
Old Jul 2, 2005 | 09:24 AM
Default Re: (pdiggitydogg)
when i bought the car i noticed the guy had put socks in those holes. i took them out not knowing what they were doing. but i dont understand what it does? u said it pushes the plastic cover up. what do u mean? thanks everyone.
Old Jul 2, 2005 | 09:37 AM
BrokeAssWhiteboy's Avatar
my house has wheels on it
i had the same problem, and fixed it with a t shirt i had that came vaccuum wrapped into this little ball, i just wedged it between the glass and deck lid and it completely cured the rattle
you might also be able to use a racquetball or something similar that will stay in place
you should have asked this in the Audio Forums, you would have gotten a better answer
Old Jul 2, 2005 | 11:02 AM
Default Re: (BrokeAssWhiteboy)
where on the deck lid did u put it to stop the entire deck from rattling?
Old Jul 2, 2005 | 11:05 AM
Just shove a sock in there again.
Its not very hard to figure out what it does...
Old Jul 2, 2005 | 11:10 AM
i shuved two big *** socks in there. it helped but it still rattles.
Old Jul 2, 2005 | 11:28 AM
It needs to be enough to press the rear deck up and in several spots
Old Jul 2, 2005 | 10:03 PM
how many spots can u put them with only 2 holes?
lilvietboy
Audio / Security / Video
Nov 5, 2008 04:16 PM
gulfview
Jan 6, 2007 04:49 PM
ekcivic9
Dec 16, 2005 02:46 PM
sportsfreak5
10
Jul 5, 2005 05:53 PM
AznJohn33
Jun 1, 2004 08:33 AM
