1st gen crx 1987 shortage on aftermarket parts!!! help plz
Hey ppl,
ive been look for parts for my 87rex but it seems that no one makes parts for it. i need ur help with locating parts.
what i found:
dc short shifter
HKS short ram intake
Pacesetter header
PAcesetter exhaust system 87rexracer
Tokico struts
Eibach lowering springs
Brembo Brakekit
what i found:
dc short shifter
Pacesetter header
Tokico struts
Brembo Brakekit
try asking the guys in the crx/EF forum.
https://honda-tech.com/zeroforum?id=3
theres quite a bit of parts out there. just have to know where to look and those guys in the ef forum will know. good luck
i pm'd you, i got new/ old stock konis that arent made anymore i have multiple sets if anyone wants some, then can be sent back to koni to be revalved into sports
The lowering springs are for the rear only. The front uses a torsion bar suspension setup. OPM Motorsports sells (or at least they used to) aftermarket torsion bars in various thicknesses to help stiffen the front end for lowering, or you can lower it with the stock torsion bars in there (not really recommended, as it cuts down on the front suspension's amount of travel under compression - i.e., bumps and dips).
For all your 1st-generation CRX needs, check out RedPepperRacing. They're the old-school CRX gurus, and can point you in the right direction for whatever performance parts are still out there. They ARE hard to find, but with patience, you can usually turn up whatever you need.
By the way, the PaceSetter headers and exhaust are not generally well-regarded. They're cheap, but they're... well, CHEAP. In every meaning of the word.
Mike
Mike
Well, if you are ghetto what you do is take an EF intake and cut like 5 inches of the TB end. Fits like a glove. We did it to my friend's 87 Si hatch.
Needs to be About 20% Cooler
i dont want to jack but theres a silver 87 CRX SI for sale here on my street. it has 213K on it for $1,100. should i get it?
