how much power can you get out of a stock wrx turbo?
Old Jun 27, 2005 | 08:53 AM
99jdem18L's Avatar
Default how much power can you get out of a stock wrx turbo?
hey im looking to get a new car i just rrecently sold my honda turbo si and i know it was probably alot faster than a wrx and everything but i am ready to move on to a REAL everyday driver. I want to get a wrx and start tuning right away. i am just wondering if id be better off to go with a turbo upgrade right away or if i could keep the stock turbo and still do a FMIC and everyhting else i wanted to without upgrading the turbo? basdically what kind of numbers are people puttin down with a stock turbo on their wrx?
Old Apr 17, 2006 | 07:36 PM
b20vtechatch
Guest
Posts: n/a
Default Re: how much power can you get out of a stock wrx turbo? (99jdem18L)
id like to know how much boost can you run safely on the td04 13g. and with that amount how much power would you get out of a b18a?
Old Apr 17, 2006 | 07:41 PM
Soccerking3000's Avatar
Default Re: how much power can you get out of a stock wrx turbo? (b20vtechatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechatch &raquo;</TD></TR><TR><TD CLASS="quote">id like to know how much boost can you run safely on the td04 13g. and with that amount how much power would you get out of a b18a?</TD></TR></TABLE>
thats reallllllly small i bet you could only run around 10 pounds on a b18 before it would just die
Old Apr 17, 2006 | 07:44 PM
b20vtechatch
Guest
Posts: n/a
Default Re: how much power can you get out of a stock wrx turbo? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">
thats reallllllly small i bet you could only run around 10 pounds on a b18 before it would just die</TD></TR></TABLE>
what would die? and only 10psi? would that at least put hp in the 250 range?
Old Apr 17, 2006 | 07:50 PM
the turbo wont be able to flow well wnough to feed the engine at higher rpms and fall flat on its face, wrx's run 14psi from the factory on the turbo's, as for hondas our engines are more efficient in the upper rpms and the turbo is too small to flow as many cfm's as the engine needs...
Old Apr 17, 2006 | 07:52 PM
b20vtechatch
Guest
Posts: n/a
how much do you think i can sell one for with 9,000 miles?
Old Apr 17, 2006 | 07:54 PM
150 bucks maybe
Old Apr 17, 2006 | 10:30 PM
alacard's Avatar
am i just the jerk here, or should this not be here at all? i mean it is HONDA-tech after all...if you want to sell out to a wrx then this should be posted in a wrx forum
Old Apr 17, 2006 | 10:58 PM
90sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99jdem18L &raquo;</TD></TR><TR><TD CLASS="quote">hey im looking to get a new car i just rrecently sold my honda turbo si and i know it was probably alot faster than a wrx and everything but i am ready to move on to a REAL everyday driver. I want to get a wrx and start tuning right away. i am just wondering if id be better off to go with a turbo upgrade right away or if i could keep the stock turbo and still do a FMIC and everyhting else i wanted to without upgrading the turbo? basdically what kind of numbers are people puttin down with a stock turbo on their wrx?</TD></TR></TABLE>
Try asking a WRX forum, you might get better results there.
Old Apr 18, 2006 | 12:35 AM
4inspeed's Avatar
Default Re: how much power can you get out of a stock wrx turbo? (89-civic-DX)
the stock turbo ON THE WRX can handle over 18 ON THE WRX. at that point dependingg ONLY on suppoerting mods should be the 300 CRANK area... DEPENDING ON MODS... wich with your awd system isnt getting you that much to the wheels... sure they build power quick but from a roll there dogs...
lsvtek
Apr 10, 2008 11:47 AM
Not_So_JDM
Jun 22, 2007 11:09 PM
jabroni95gsr
May 14, 2003 01:10 AM
scooter
Jul 15, 2002 09:40 PM
