swap from an EG
ok theres a swap(b18c1) in an eg hatch thats wanting to sell it.
i have a 98 coupe.what would i have to get to make these compatable.i was htinking that the mounts wouldnt work,but what about hte mount brackets and harness jumper.what obd is an eg?
eg is OBD1, however it may be converted to run the engine. b18c1s were made in 3 different OBD generations as far as I know. I don't know why the mounts wouldn't work, as far as I'm aware egs and eks share identical mounts/engine bays.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydiR »</TD></TR><TR><TD CLASS="quote">eg is OBD1, however it may be converted to run the engine. b18c1s were made in 3 different OBD generations as far as I know. I don't know why the mounts wouldn't work, as far as I'm aware egs and eks share identical mounts/engine bays.</TD></TR></TABLE>
eg's and ek's have different mounts.......94 & 95 ex/si use the same mounts as the gsr except for the tranny rear bracket and the lower vibration brackets.
https://honda-tech.com/zerothread?id=878010
Imagine that, a helpful link that you would see (if you'd look) right before you posted. I'm sure you could get your questions answered by looking around.
vote: LOCK
vote: LOCK
sorry, ive looked in there plenty of times but i wasnt looking for that info so i overlooked it.and didnt think to look in there since i knew what swaps were available for my civic,but wasnt sure on obds
any part numbers for the brackets?
Civic2Fast
May 23, 2008 07:55 AM
HondaFanatic708
Apr 5, 2005 07:36 PM
