5Lug on EK suspension questions
Old Jun 26, 2005 | 09:37 PM
CHAMPwhteEK's Avatar
Default 5Lug on EK suspension questions
i just got done putting a 2000 Type R 5Lug conversion on my 99 EK hatchback now i need to lower. so my question is... do i buy suspension peices for a type R or still for a EK
Old Jun 26, 2005 | 09:43 PM
Street Ghost's Avatar
Default Re: 5Lug on EK suspension questions (CHAMPwhteEK)
depends.. if they are brake suspension parts, then u buy for the Type R. but if they are coilovers/shocks.. u buy for the EK unless u switched the rear LCA to the ITR one.
Old Jun 26, 2005 | 10:35 PM
BlueIntegraBoy's Avatar
Buy suspension parts for an EK. If you used CTR rear LCAs, then you need to buy struts for an ITR/CTR.
Old Jun 26, 2005 | 10:48 PM
JDM PRO's Avatar
Default Re: 5Lug on EK suspension questions (BlueIntegraBoy)
ek suspension parts w/ your ek lcas
Old Jun 26, 2005 | 11:11 PM
=SnEekY-Dc5='s Avatar
Default Re: 5Lug on EK suspension questions (JDM PRO)
if you did it the right way then you probably didnt use the itr one....so you should buy ek suspension parts not itr....unless you use the washer trick...
Old Jun 26, 2005 | 11:13 PM
slowpokecivic's Avatar
Default Re: 5Lug on EK suspension questions (=SnEekY-Dc5=)
that was me posting up there...didnt realize my cousin was signed on..but yea either way your fine...
Old Jun 27, 2005 | 12:19 AM
ej0513's Avatar
whoa.. i think almost everyone here that responded may be wrong in some way or another..
you have an EK, buy suspension for an EK.. ITRs have the "eye" mount on the bottom of the shock which needs ITR LCAs that fit ONLY on EGs and DCs. EKs cannot use that LCAs because the length of the LCA is different. you can buy EG or Non-R DC suspension but youll have to do the washer trick. so in the end.. 5 lug or not you need EK suspension, your only changing the trailing arm.
Old Jun 27, 2005 | 03:29 AM
96BlackHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM PRO &raquo;</TD></TR><TR><TD CLASS="quote">ek suspension parts w/ your ek lcas</TD></TR></TABLE>
This is correct. It seems like half the people in this thread don't have a f*cking clue
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 &raquo;</TD></TR><TR><TD CLASS="quote">whoa.. i think almost everyone here that responded may be wrong in some way or another..
you have an EK, buy suspension for an EK.. ITRs have the "eye" mount on the bottom of the shock which needs ITR LCAs that fit ONLY on EGs and DCs. EKs cannot use that LCAs because the length of the LCA is different. you can buy EG or Non-R DC suspension but youll have to do the washer trick. so in the end.. 5 lug or not you need EK suspension, your only changing the trailing arm.</TD></TR></TABLE>
Finally, someone who knows something
Old Jun 27, 2005 | 11:25 AM
Kidnkorner's Avatar
Default Re: 5Lug on EK suspension questions (96BlackHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96BlackHB &raquo;</TD></TR><TR><TD CLASS="quote">
This is correct. It seems like half the people in this thread don't have a f*cking clue </TD></TR></TABLE>
W<FONT SIZE="4">3</FONT>rd! Internet know it all wannabe's
Learn something new everday here.
Old Jun 27, 2005 | 11:54 AM
Nova_Dust's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">If you used CTR rear LCAs, then you need to buy struts for an ITR/CTR.</TD></TR></TABLE>
So, you are suggesting that ITR/CTR shares the same rear struts? Good call.
NaturalTone
Suspension & Brakes
May 22, 2012 07:23 PM
SoCaLNaTIvE
Feb 18, 2004 07:40 AM
Blown90hatcH
14
Apr 6, 2002 12:17 AM
