turbo sohc...run like shit..need help..
Old Jun 26, 2005 | 09:29 PM
mr. vang's Avatar
Default turbo sohc...run like ****..need help..
okay..finally turbo my y8 motor...cause i got a cheap *** turbo kit...okay the problem is that every time i try to dyno tune it first gear would want to kill out...sometimes it actully runs and at 5 grand the motor would not produce any power at all..i have no clue whats wrong..i would say **** it and drove the car home...have walbro 255, dsm 390, vafc, and only running 5 psi of boost..i know that 390 on the hack cant really do much but hey they were free..still looking for a set of 450s...what seems to be the problem...first day the kit when on it ran fine but then it ran shitty...like it wants to boost but it cant...i dont know its killingme guys...i started out with the setting at -20 across the board and tuned from there and still ran like ***..fuel pressure was turned all the way up to 50 some psi..
Old Jun 26, 2005 | 09:31 PM
GiNuWiNe's Avatar
Default Re: turbo sohc...run like ****..need help.. (jdm_whore)
Your probably running really rich, are you even using a wideband to tune?
Old Jun 26, 2005 | 09:35 PM
SOHC_MShue's Avatar
yea what are your afr's like?
Old Jun 26, 2005 | 09:37 PM
mr. vang's Avatar
Default Re: turbo sohc...run like ****..need help.. (GiNuWiNe)
the dyno where i went had wide band...so we used it but still no help..see what happends when i get 450s ..still it bothers me...first when not tuned it ran with boost.. now boost kicks in really late..like at 5k, used to at 2500-3000...(ihi turbo)
Old Jun 26, 2005 | 09:38 PM
mr. vang's Avatar
Default Re: turbo sohc...run like ****..need help.. (SOHC_MShue)
still running very lean no matter what..
Old Jun 26, 2005 | 09:39 PM
GiNuWiNe's Avatar
So what are your AFR's at..
Old Jun 26, 2005 | 09:45 PM
mr. vang's Avatar
was like around 13:1 i think dont remember..was like a week ago when it was getting tuned..
Old Jun 26, 2005 | 10:33 PM
GiNuWiNe's Avatar
thats pretty lean you want to be around 12:5:1 - 11:5:1
Old Jun 27, 2005 | 08:31 PM
mr. vang's Avatar
yeah we were shooting for 12:1 but we couldnt get it to go any more richer..
Old Jun 27, 2005 | 08:38 PM
SOHCmaster's Avatar
Put that down to 38-39psi.. Put 240cc back and keep under 10psi and should work fine.
Old Jun 27, 2005 | 08:49 PM
twkdCD595's Avatar
Default Re: (PK SPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED &raquo;</TD></TR><TR><TD CLASS="quote"> Put that down to 38-39psi.. Put 240cc back and keep under 10psi and should work fine.</TD></TR></TABLE>
what??!?? maybe I am reading this wrong cause I am about super tired... but... he needs more fuel not less. sleep calls.
Old Jun 27, 2005 | 09:35 PM
VRD^don's Avatar
really...
Old Jun 27, 2005 | 10:28 PM
2kTeg's Avatar
Default Re: (sohc_Vtec)
390's should be enough for under 10lbs
Old Jun 27, 2005 | 11:13 PM
wpgcivic's Avatar
your car is just dying for a good tune man
Old Jun 28, 2005 | 07:48 AM
93turbo16's Avatar
What is the plug gap set at?
Old Jun 28, 2005 | 07:55 AM
lkailburn's Avatar
you took it to get dyno tuned then took it off cuz you wanted to get mad at it at home? lol KEEP IT ON THE DYNO so you can test all your junk haha. i mean obviously make sure you have everything physically connected right first but you'll be fine with 390cc for now. take it back to the dyno and work with your timing as well. your timing might be waaay retarded. also check for dumb **** like spark plugs and stuff.
also get a datalogging session going to make sure your sensor's are reading correctly.
get her on the dyno tune
IT'S ME DAVID
Sep 10, 2009 10:33 PM
954bballer091
Sep 14, 2008 01:04 PM
fjt
Jun 15, 2005 05:07 AM
Edgemingsr
Jan 28, 2004 06:08 PM
TORQUE MONSTER
Jul 4, 2003 07:22 PM
