ways to brace ss autochrome manifold?
you can't change the fact that the metal is an inferior alloy and way too thin of a gauge to begin with. It's still gonna crack with those braces, but at least now your turbo won't fall off completely. good luck though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by as_fast_as_u »</TD></TR><TR><TD CLASS="quote">brace yourself...............sscrapofold suck dick</TD></TR></TABLE>
Muhahahahhaahhahahahahahahahhahahahahhahahahah
when the manifold gets hot, those braces will brake off. happend about 3 times to my buddy.
you really wanna brake up the turbo. brace the downpipe down to the block the it is from the factory. these things will still crack.
good luck
good luck
You need a brace from the block to turbo. The turbo should be able to sit on the brace with it's full weight on it. Then attach the manifold. All manifolds will crack, this one just does it very very fast.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000psi »</TD></TR><TR><TD CLASS="quote">you can't change the fact that the metal is an inferior alloy and way too thin of a gauge to begin with. It's still gonna crack with those braces, but at least now your turbo won't fall off completely. good luck though</TD></TR></TABLE>
Bracing the turbo flange to the head flange will do dick all. It will still break. You need to do as previously staated and brace the TURBO to the BLOCK
Bolted to oil inlet flange
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">Bracing the turbo flange to the head flange will do dick all. It will still break. You need to do as previously staated and brace the TURBO to the BLOCK
Bolted to oil inlet flange</TD></TR></TABLE>
yeah, thats my setup. It's been on for a little over a year now without any problems. The brace attachs from the stock AC mount bolt hole to one of the 4 bolts on the turbine housing and is adjustable by adding more washers to the bolt to releive more weight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol »</TD></TR><TR><TD CLASS="quote">trash can will hold it in place </TD></TR></TABLE>
Gots my vote for best bracing method!!!!
soooo may asshats buy these even after reading all the posts.
Makes me want to buy up all the shitty ones no one wants because they know how shitty they are, and sell them to the 2005 noobs!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">
Makes me want to buy up all the shitty ones no one wants because they know how shitty they are, and sell them to the 2005 noobs!!!</TD></TR></TABLE>
I'll sell this one to some stupid 05 noob
Plug the oil return
Plug the oil return
Who is Mr Robot?
i braced mine like those pics up top. i have my turbo sitting like that too, putting a huge moment on the top of the runners next to the flange. but nothing has broke or cracked yet. and have put like 7000 miles on it, beating the living crap out of my car. I even heat wrapped it, which some say is bad for it. but i have had no problems yet and have seen it turn birght orange on numerous occasoins
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke »</TD></TR><TR><TD CLASS="quote">i braced mine like those pics up top. i have my turbo sitting like that too, putting a huge moment on the top of the runners next to the flange. but nothing has broke or cracked yet. and have put like 7000 miles on it, beating the living crap out of my car. I even heat wrapped it, which some say is bad for it. but i have had no problems yet and have seen it turn birght orange on numerous occasoins
Screw that. I'd take a real manifold like my new one over any SS Autochrome, OBX, ETC Manifold
</TD></TR></TABLE>Screw that. I'd take a real manifold like my new one over any SS Autochrome, OBX, ETC Manifold
Silversupragirl
Apr 26, 2004 10:39 PM
