88 si motor in a 91 crx si, any wiring differences??
Old Jun 26, 2005 | 08:12 PM
prjctCIVIC's Avatar
Default 88 si motor in a 91 crx si, any wiring differences??
i put a 88 crx si motor in my 91 crx si and i used the 88 si wiring and i noticed on the injector resistor box side theres a white plug with 8 pins on the crx body side and on the 88 si engine wiring harness it has a 6 pin connector, does anyone know what the other 2 pins are for on the body side of my crx si?? or if anyone can point me to a 91 si online manual, ive looked at 88-89 manuals and it doesnt mention these wires, thanks
Old Jun 26, 2005 | 11:15 PM
crx-treme's Avatar
Default Re: 88 si motor in a 91 crx si, any wiring differences?? (prjctCIVIC)
i put a 90 si motor into an 89 si, didnt notice differences. idkif that helps what so evver. is it done/does it run?
Old Jun 26, 2005 | 11:16 PM
UltimX's Avatar
its not goin to be smog legal. The difference is the distributor for wiring.
Old Jun 27, 2005 | 09:17 AM
prjctCIVIC's Avatar
Default Re: 88 si motor in a 91 crx si, any wiring differences?? (UltimX)
it starts up and but still in the air, im getting a code 6, 9, 10. i guess i gotta figure out the wiring for the distributor, any ideas what i need to do?? anybody got a 91 crx si online maual??
Old Jun 27, 2005 | 11:50 AM
bagpipe goatee's Avatar
i know the 88 harness is really weird compared to other years. try to find a 90-91 harness if possible, otherwise you'll have rewire a lot.
Old Jun 27, 2005 | 01:22 PM
Sikocivic's Avatar
Default Re: (bagpipe goatee)
Always use the harness that came with the car and modify it to fit the "new" motor.
Old Jun 27, 2005 | 01:25 PM
DUFFM4N's Avatar
Default Re: (Sikocivic)
distributor
Old Jun 27, 2005 | 01:38 PM
prjctCIVIC's Avatar
Default Re: (EF9eDDie)
i found the problem to be in the right shock tower harness. 4 wires were switched around on the 88 si harness, repinned it to the right locations and fired it up and no cel, thanks for everyones help
Old Jun 27, 2005 | 01:45 PM
NikoZai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">Always use the harness that came with the car and modify it to fit the "new" motor.</TD></TR></TABLE>
he has been paying attention in honda class.
You should use the engine harness that came with that chassis so that all the connections match the chassis harness wiring. If you were going Si to Si... there are no changes at the engine. Everything would be the same, so use the same year engine harness.
Good that you fixed it, but for future reference for others, you want to just use the harness that came with the car because it would have plugged in exactly the same
Old Jun 27, 2005 | 06:30 PM
prjctCIVIC's Avatar
Default Re: (NikoZai)
the car came with an ls motor and had bunch of problems and who ever put in the motor hacked up the wiring harness and i didnt want to bother with cleaning it up, and since the si swap came with everything intact i figured it couldnt be that different in wiring, which it wasnt. just switched a few pins and viola no more CEL
dylaxiin
Nov 10, 2011 07:43 PM
jslater2306
Dec 7, 2007 07:04 PM
10ktgold
Oct 25, 2003 09:54 AM
KevronsEG
Mar 8, 2003 07:46 PM
